The “common” INA219 modules have a R100 shunt resistor fitted. Has anyone tried replacing the on-board R100 (0.1ohm) with 1R00 (0.01ohm)?
If so, how will the ESPHOME yaml code change? My guess is that I will need to “dig deeper”?
Where would the library for the INA219 for the esphome compiler live so that I can have a look at it?
Since raising the question, I have gone off the idea of measuring the voltage drop across a resistor and switched to a Hall Effect device (in my case the ACS724LLCTR-20AU-S which is a unidirectional 0-20A - there is also a 0-30A version!).
