Hello, maybe someone can guide me on how I can configure my modem to access Home Assistant from outside my house through DuckDNS? (Port Forwaring)
I am attaching some photos of the modem control panel, thanks.
the port forwarding rules say “No” to enabled?
Thank you for responding good human being, well, I have to confess that the day I did the tests I slipped into oblivion to select the ENABLE´activation box. I want to tell you that I have already damaged 3 SD32GB memories by reinstalling the HASSOS image to try to access my assistant outside the local network, now I am learning about TAILSCALE but I would like to learn with DuckDNS since it is an own AddOnn; I work on a RaspberryPi4 _RAM2gb, I am also suspicious of the USB_sd-card adapter with which I transfer the data from the computer, I understand that it may be of poor quality. Please can you give me your opinion if Maybe you can tell me if the way to configure DuckDNS in the following video is reliable? : Addon DuckDNS, acceder a tu Home Assistant desde cualquier sitio | Home Assistant Addons - YouTube Do you think I can perform the video procedure again and only by selecting the activation box?
I have performed the steps described in the video to which the link leads, after restarting the modem and the raspberry I can never find my X.X.X.X:8123, I am a little afraid that another SIM will be damaged.
