Been struggling with a move from Wink to HASS, trying to get Zwave started and the errors aren’t being self explanatory. I’ve tried both /dev/ttyACM0 and the direct path, both seem to open then choke as below. I’m using a Zooz S2 Plus USB adapter running a HASS ESXi image, up to date. What am I missing here?
serial:
/dev/ttyACM0
/dev/ttyS0
/dev/ttyS3
/dev/ttyS1
/dev/ttyS2
/dev/serial/by-id/usb-0658_0200-if00
input:
Power Button
ImPS/2 Generic Wheel Mouse
VMware VMware Virtual USB Mouse
AT Translated Set 2 keyboard
disk:
gpio:
audio:
2020-06-02 16:33:31.948 Always, OpenZwave Version 1.4.3469 Starting Up
2020-06-02 16:33:38.888 Info, Setting Up Provided Network Key for Secure Communications
2020-06-02 16:33:38.888 Info, mgr, Added driver for controller /dev/serial/by-id/usb-0658_0200-if00
2020-06-02 16:33:38.888 Info, Opening controller /dev/serial/by-id/usb-0658_0200-if00
2020-06-02 16:33:38.888 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200-if00 (attempt 1)
2020-06-02 16:33:39.081 Info, Serial port /dev/serial/by-id/usb-0658_0200-if00 opened (attempt 1)
2020-06-02 16:33:39.082 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-02 16:33:39.082 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-02 16:33:39.082 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-02 16:33:39.082 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-02 16:33:39.082 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-02 16:33:39.082 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-02 16:33:39.086 Warning, WARNING: Out of frame flow! (0x61). Sending NAK.
2020-06-02 16:33:39.094 Warning, WARNING: Out of frame flow! (0x20). Sending NAK.
2020-06-02 16:33:39.100 Warning, WARNING: Out of frame flow! (0x30). Sending NAK.
2020-06-02 16:33:49.083 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 16:33:49.083 Detail, contrlr, Removing current message
2020-06-02 16:33:49.083 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 16:33:49.083 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-02 16:33:49.174 Detail, Unsolicited message received while waiting for ACK.
2020-06-02 16:33:49.681 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2020-06-02 16:33:49.770 Detail, Unsolicited message received while waiting for ACK.
2020-06-02 16:33:50.271 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2020-06-02 16:33:50.271 Warning, WARNING: Out of frame flow! (0x20). Sending NAK.
2020-06-02 16:33:50.273 Detail, Unsolicited message received while waiting for ACK.
2020-06-02 16:33:50.773 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2020-06-02 16:33:50.773 Detail, Unsolicited message received while waiting for ACK.
2020-06-02 16:33:51.273 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2020-06-02 16:33:51.273 Warning, WARNING: Out of frame flow! (0x20). Sending NAK.
2020-06-02 16:33:51.401 Detail, Unsolicited message received while waiting for ACK.
2020-06-02 16:33:51.401 Detail, contrlr, Received: 0x01, 0x01, 0x02
2020-06-02 16:33:51.401 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2020-06-02 16:33:51.401 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:33:51.408 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:33:51.411 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:33:51.418 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:33:51.421 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:33:52.421 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 16:33:52.421 Detail, contrlr, Removing current message
2020-06-02 16:33:52.421 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 16:33:52.422 Detail,
2020-06-02 16:33:52.422 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-02 16:33:53.422 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 16:33:53.423 Detail, contrlr, Removing current message
2020-06-02 16:33:53.423 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 16:33:53.423 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-02 16:33:53.427 Warning, WARNING: Out of frame flow! (0x07). Sending NAK.
2020-06-02 16:33:53.427 Warning, WARNING: Out of frame flow! (0x03). Sending NAK.
2020-06-02 16:33:53.429 Detail, Unsolicited message received while waiting for ACK.
2020-06-02 16:33:53.442 Detail, contrlr, Received: 0x01, 0x02, 0x87, 0x88
2020-06-02 16:33:53.442 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2020-06-02 16:33:53.445 Warning, WARNING: Out of frame flow! (0x2b). Sending NAK.
2020-06-02 16:33:53.445 Warning, WARNING: Out of frame flow! (0x07). Sending NAK.
2020-06-02 16:33:53.445 Warning, WARNING: Out of frame flow! (0x02). Sending NAK.
2020-06-02 16:33:53.445 Warning, WARNING: Out of frame flow! (0x7a). Sending NAK.
2020-06-02 16:33:53.445 Warning, WARNING: Out of frame flow! (0x04). Sending NAK.
2020-06-02 16:33:53.447 Warning, WARNING: Out of frame flow! (0x02). Sending NAK.
2020-06-02 16:33:53.451 Warning, WARNING: Out of frame flow! (0x87). Sending NAK.
2020-06-02 16:33:53.457 Warning, WARNING: Out of frame flow! (0x88). Sending NAK.
2020-06-02 16:33:54.457 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 16:33:54.457 Detail, contrlr, Removing current message
2020-06-02 16:33:54.457 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 16:33:54.457 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-02 16:33:54.464 Warning, WARNING: Out of frame flow! (0x04). Sending NAK.
2020-06-02 16:33:54.467 Warning, WARNING: Out of frame flow! (0x56). Sending NAK.
2020-06-02 16:33:54.468 Warning, WARNING: Out of frame flow! (0x56). Sending NAK.
2020-06-02 16:33:54.468 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:33:54.469 Warning, WARNING: Out of frame flow! (0xac). Sending NAK.
2020-06-02 16:33:54.472 Warning, WARNING: Out of frame flow! (0x04). Sending NAK.
2020-06-02 16:33:54.477 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-02 16:34:02.032 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2020-06-02 16:34:02.032 Warning, WARNING: Out of frame flow! (0x0f). Sending NAK.
2020-06-02 16:34:02.041 Detail, contrlr, Received: 0x01, 0x06, 0x64, 0x0f, 0x96, 0x01, 0x01, 0x06
2020-06-02 16:34:02.041 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2020-06-02 16:34:02.047 Warning, WARNING: Out of frame flow! (0x0f). Sending NAK.
2020-06-02 16:34:02.051 Warning, WARNING: Out of frame flow! (0x96). Sending NAK.
2020-06-02 16:34:02.057 Warning, WARNING: Out of frame flow! (0x05). Sending NAK.
2020-06-02 16:34:02.560 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2020-06-02 16:34:02.560 Warning, WARNING: Out of frame flow! (0x64). Sending NAK.
2020-06-02 16:34:04.458 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 16:34:04.458 Detail, contrlr, Removing current message
2020-06-02 16:34:04.458 Detail, contrlr, Notification: Notification - TimeOut
