Hi all,
Coming from ST I had a location mode to choose from. Home, Away, Day and Night.
This could be set as a condition.
Does HA have something similar?
Hi all,
look at helpers - in particular the Times of Day helper. You could set up a helper for Home, Away, Day and Night and configure the time frames. These create a simple switch that is exposed and usable as conditions in automations. see here: Integrations - Home Assistant (home-assistant.io)
you could also look at the sun entity and use offsets see here: Sun - Home Assistant (home-assistant.io)
hope this helps - I think there are few time of day posts on here so have a search - if i find one of the ones I’ve seen I’ll share
