Modify an input_select value from a script
Despite the infos found, haven’t found infos to solve my issue.
I have a MQTT input_select command topic:
  mqtt:
    select:
      - command_topic: "evcc/loadpoints/1/mode/set"
        unique_id: evcc_gg_mode_select
        icon: mdi:tune-variant
        state_topic: "evcc/loadpoints/1/mode"
        value_template: >
            {% if value == 'off' %}
              Off
            {% elif value == 'pv' %}
              Solo solare
            {% elif value == 'minpv' %}
              Min. + solare
            {% else %}
              A manetta
            {% endif %}
        command_template: >
            {% if value == 'Off' %}
              off
            {% elif value == 'Solo solare' %}
              pv
            {% elif value == 'Min. + solare' %}
              minpv
            {% else %}
              now
            {% endif %}
        options:
          - "Off"
          - "Solo solare"
          - "Min. + solare"
          - "A manetta"
And a script with multiple actions, one of those:
service: input_select.select_option
  option: Solo solare
  entity_id: select.evcc_gg_mode
alias: Imposta Modalità Ricarica PV
No errors when it is executed, but the value does not change.
The script is made via UI, and I’ve noticed also that HA tells me “No entity found”, if i try to build the script action via the ui:
If i manually edit the yaml:
in entities list:
I’m going crazy. i’ve tried with brackets, with original values (pv, minpv etc), other shyntax who don’t give errors, but still doesn’t work.
Here the (un)successful trace relative to submitted config:
where i am wrong?
That’s because you created a select entity but are attempting to set its value using a service call meant for an input_select entity.
Change input_select.select_option to select.select_option.
Many thanks for the quick reply! :heartbeat:
Works as expected
