I am a new smart-homer and really pumped Bought a NAS with N100 CPU and everything works like a charm (HA OS is running in a virtual mashine on my linux OS).
I integrated a lot of devices I have, including 2 Air-Conditioner. The most important is the Panasonic VZ9 I have for heating, and its connected via the Panasonic Comfort Cloud Integration. (yeah I learned in the hours of videos I saw, that cloud is not a elegant solution, but I have a small child and no time for a direct adapter solution at the moment).
The Entity is also in the system, but I have the strange situation that the attributes for the mode of the AC (hvac_modes: off, cool, dry, fan_only) is incomplete. The AC is running on “heat” mode, but I cannot SET the heat mode. Cause its not part of the list of the attributes. When I go into the developer-tool menu and open the entity, I can see the attributes. I add the “Heat” attribute manually to the config and click “SET”. For some seconds also the “heat” option appears in the menu, I can chose it, but then it disapears from the list and therefore from the menu.
That is unfortune because I want to make an automation that sets the AC to different states (also heat) under certain conditions. But the heat hvac_mode is not selectable.
I will continue watch videos and tutorials, but It is sooo many hours of videos and I thought I got the solution with this configuration, but it seems as I cannot save the attribute
Thank you! I directly run into the next issue that is pretty much related: I want to change also the temperature (and I think my problem will apply to any further change like fanspeed etc.). I use the Code of the HVAC automation, copy it and modify just the hvac mode. If I do it in the YAML mode in the automation-workspace, i get an error. So I directly modified it in the editor in the automation config, but there the same error appears: “Message malformed: not a valid value for dictionary value @ data[‘type’]”
I take the working automation for the hvac mode (based on what Home Assistant Creates in the YAML Code when I use the visual editor as base):
alias: Temp Test
description: ‘’
triggers:
The automation “Temp Test” (automation.temp_test) is not active because its actions could not be set up.
Error:extra keys not allowed @ data['temperature']. Got None not a valid value for dictionary value @ data['type']. Got None required key not provided @ data['hvac_mode']. Got None
What makes this so strange for me is: HOW does Home Assistant knows that it was “hvac_mode”? I mean I changed the code and evereything hvac related is deleted and interchanged with the temperature.
Where is my error? I mean I CAN change the temp with the action mode. Just dont know how to translate action-mode code into automation code. I tried to exchange the part in the YAML COde of the automation fron the “actions” part on with my code that works in actions, but that doesnt work at all
