I’m trying to use the CISCO device tracking add-on and having a few issues. When HAS starts I get the below in the log file:
2019-02-01 00:18:52 ERROR (SyncWorker_4) [homeassistant.components.device_tracker.cisco_ios] pxssh failed on login
2019-02-01 00:18:52 ERROR (SyncWorker_4) [homeassistant.components.device_tracker.cisco_ios] Could not establish connection to host
2019-02-01 00:18:52 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform cisco_ios
Looking at the log on my router I see the following:
No matching cipher found: client chacha20-poly1305@openssh
I can re-create the error if I open a shell to the HAS container and run the SSH command directly. Simple fix is to un-comment the cipher line in /etc/ssh/ssh_config
The problem I have is making this persistent! I need to restart HAS to retry device discover, which immediately removes my SSH_Config edit!
What’s the best way to get this edit applied and persisting when the container starts.
That would have been good to know in the first post. Since your question was about Docker container specifically, I assumed you were running normal Docker, on Linux, and not HASSIO on HASSOS, which means you do not have these options available to you.
Assuming nobody knows the exact solution, here’s something you could try (which I have not)…
Can you specify the cipher on the SSH command (ie. ssh -c chacha20-poly1305@openssh)? If this works manually, you could try copying cisco_ios.py into the custom components folder and update the code to do the same thing (if possible). Having a look here suggests
cisco_ssh = pxssh.pxssh(options={...})
However it’s not immediately obvious how you’d specify the cipher.
