I setup the Hyper-V image, setup a (trial) of Home Assistant cloud, and am largely on my way. But I want nest support, so I need to edit my config file.
Is it not possible to access it using the hyper-v setup?
You need to install Samba Share add-on. This will allow you to access all configuration files inside HA from other computer.
Thanks a ton!
