Modify Fcmila bulbs
Hi!
I recently brought some Fcmila RGBW bulbs and I discovered that they switched to a new app (“Cloud Intelligence”) and they cannot be flashed with tuya-convert.
I opened a bulb and found a new daughter board, based on the OPL1000 chip:
I’m trying to replace it with an ESP-12 board to make it work with Tasmota and HA.
I checked with an oscilloscope the pins when controlling the board with the official APP… on RGB pins I was able to find the expected PWM signal (4KHz) that changes its duty cycle depending on the brightness and color I choose.
What I cannot understand is the “C” and “W” pins… I thought W was for the white leds, but it stays flat (referred to GND), while the “real” white PWM outputs from pin C.
I connected an ESP-12 module to pins GND and 3.3V and it works… but when I try to connect a pin (for example D4) to the main board the blue led of the module stays ON and I cannot connect to the esp chip…
Do you have any ideas?
Thanks!
the problem occurs only if I connect the top board (the one with LEDs).
If I connect, for example, PWM1 to RED pin, when I power it on the RED leds are on at the max brightness and the esp board doesn’t boot (blue led fixed)
I suspect that
C = cold (white)
W = warm (white)
my bulb has only cold white so it should be ok that W signal is always GND…
I still have to figure out why, if I connect the LED board, the ESP12 is stuck.
In addition I reverse engineered the LED board… it has 3 MOSFET for RGB but only one “power” pin for white leds…:
I have the exact same board. Did you get this light working?
Also, why did you choose Tasmota and not esphome?
Yes, and I documented it on my blog:
http://www.lucadentella.it/en/2020/11/27/modificare-una-lampadina-smart-parte-1/
I chose Tasmota simply because it’s the firmware I’m using for all my smart devices… but as soon as you modify the lamp, you can upload the firmware you prefer.
