Modify LED behavior of ESPHome switch
text_sensor:
  - platform: libretiny
    version:
output:
  - platform: gpio
    pin:
      number: P14
      inverted: true
  - platform: libretiny_pwm
    pin:
      number: P26
      inverted: true
  - platform: gpio
    pin:
      number: P11
      inverted: true
light:
  - platform: binary
    output: output_led_1
  - platform: monochromatic
    output: output_led_2
  - platform: binary
    output: output_led_3
binary_sensor:
  - platform: gpio
    pin:
      number: P24
      inverted: true
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.toggle: switch_1
  - platform: gpio
    pin:
      number: P20
      inverted: true
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.toggle: switch_2
  - platform: gpio
    pin:
      number: P7
      inverted: true
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.toggle: switch_3
switch:
  - platform: gpio
    pin: P6
    on_turn_on:
      - light.turn_on: light_switch_1
    on_turn_off:
      - light.turn_off: light_switch_1
  - platform: gpio
    pin: P8
    on_turn_on:
      - light.turn_on: light_switch_2
    on_turn_off:
      - light.turn_off: light_switch_2
  - platform: gpio
    pin: P9
    on_turn_on:
      - light.turn_on: light_switch_3
    on_turn_off:
      - light.turn_off: light_switch_3
status_led:
  pin:
    number: P22
    inverted: true
Current
  1. Above works fine
  2. When lights are off, switch LED is red
  3. When lights are on, switch LED is blue
Desired
  1. When lights are off, switch LED is off (no red/blue)
  2. When lights are on, switch LED is blue
I believe it is possible because I tried changing output.platform to libretiny_pwm for output_led_1 and 3, I was still able to toggle switches 1 and 3 but their LED becomes always off.
Can help? Thank you!
