since I used modbus on HA I had many and many problems with any device, sometimes bypassed using Nodered. Now I want to try a definitive solution using linux version (x86_64-linux-gnu) of MODPOLL (Free Modbus Master Simulator and Test Tool). I tried to upload it on HA /config/temp folder, chmod 777 and execute. It worked! I have always the right reading values for every device.
./modpoll -t 4:float -f -r 45166 -o 5 -i -c 4 -1 192.168.1.120
modpoll 3.10 - FieldTalk(tm) Modbus(R) Master Simulator
Copyright (c) 2002-2021 proconX Pty Ltd
Visit https://www.modbusdriver.com for Modbus libraries and tools.
Protocol configuration: MODBUS/TCP, FC3
Slave configuration...: address = 1, start reference = 45166, count = 4
Communication.........: 192.168.1.120, port 502, t/o 5.00 s, poll rate 1000 ms
Data type.............: 32-bit float, output (holding) register table
Word swapping.........: Slave configured as big-endian word and float machine
-- Polling slave...
[45166]: 3511.693115
[45168]: 0.000000
[45170]: 746.195984
[45172]: 90.900002
Now, I want to install correctly Modpoll on HA in order to execute it from a script on HA and get the values on a sensor (e.g. command line sensor)
Can you give me some suggestion?
