Hello
I have a problem after updating. I had updated HA (core installation) last time on 07/07, then upgraded today to 2022.8.9. After the first “boot”, I saw this error in the log:
Error setting up entry localhost for mqtt
File "/home/homeassistant/.pyenv/versions/3.9.7/lib/python3.9/site-packages/homeassistant/config_entries.py", line 357, in async_setup
result = await component.async_setup_entry(hass, self)
File "/home/homeassistant/.pyenv/versions/3.9.7/lib/python3.9/site-packages/homeassistant/components/mqtt/__init__.py", line 463, in async_setup_entry
await async_forward_entry_setup_and_setup_discovery(entry)
File "/home/homeassistant/.pyenv/versions/3.9.7/lib/python3.9/site-packages/homeassistant/components/mqtt/__init__.py", line 456, in async_forward_entry_setup_and_setup_discovery
await _async_setup_discovery(hass, conf, entry)
File "/home/homeassistant/.pyenv/versions/3.9.7/lib/python3.9/site-packages/homeassistant/components/mqtt/__init__.py", line 162, in _async_setup_discovery
await discovery.async_start(hass, conf[CONF_DISCOVERY_PREFIX], config_entry)
File "/home/homeassistant/.pyenv/versions/3.9.7/lib/python3.9/site-packages/homeassistant/components/mqtt/discovery.py", line 246, in async_start
hass.data[DISCOVERY_UNSUBSCRIBE] = await asyncio.gather(
File "/home/homeassistant/.pyenv/versions/3.9.7/lib/python3.9/site-packages/homeassistant/components/mqtt/discovery.py", line 248, in <genexpr>
mqtt.async_subscribe(hass, topic, async_discovery_message_received, 0)
AttributeError: module 'homeassistant.components.mqtt' has no attribute 'async_subscribe'
So my MQTT extension stopped working.
What can I do? I checked in the release notes but found nothing that seemed related.
I tried to remove and add again the MQTT integration, but same issue
