I will install Toon library i use Crooncat / Toonha as the common Toon module can not be installed at Hassio (With Hassio you can not use command line like Terminal (Mac) or Putty (Win) So i did copy 3 files maps to /config and input the code into configuration.yaml
Although Yamllint says code ok i got invalid config. What is wrong?
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 0
longitude: 0
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: UTC
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
Track the sun
sun:
Sensors
Weather prediction
- platform: yr
Text to speech
tts:
- platform: google
Cloud
cloud:
toon:
username: myusername
password: mypassword
consumer_key: eJQZbo********
consumer_secret: Tesxi*******
group: !include groups.yaml
script: !include scripts.yaml
