Moes 4-Button Scene Controller - Zigbee2MQTT (Model: TS0044)
Moes 4-Button Scene Switch Z2M (TS0044) Blueprint
Easily Automate TS0044 Devices Paired via Zigbee2MQTT (Z2M)
Description
This blueprint is designed for the Moes 4-Button Scene Switch (TS0044), integrated with Zigbee2MQTT. It condenses all 12 unique button actions for a Scene Switch into a single, easy-to-maintain automation. It supports the following actions for each button:
  • Single Press – single_press
  • Double Press – double_press
  • Hold – hold_press
This blueprint allows you to quickly and easily configure multiple actions for each button on the scene switch, making it a versatile tool for managing your smart home devices.
Prerequisites
Ensure your device is properly integrated with Zigbee2MQTT. You’ll need to locate the MQTT topic associated with your scene switch before setting up the blueprint.
Note:
  • To expose the actions in Z2M for use in Home Assistant automations, I needed to manually select each button/action on the Scene Switch (e.g., single-click, double-click, and hold every button on the device following initial pairing with Z2M). Without this step, Home Assistant didn’t seem to recognize the actions in the automation YAML.
  • If you run into this issue, try this out to see if the actions are exposed and registered in Home Assistant. If that doesn’t work, try trailing the Z2M logs and monitor action payloads to that MQTT topic. Every payload reference for each value_template in the YAML below should match the actions exposed by your device.
Steps to find your device’s MQTT topic:
  1. Navigate to the Zigbee2MQTT integration in Home Assistant.
  2. Select “Logs” from the ribbon header.
  3. Press any button on your Moes Scene Switch.
  4. Locate the latest log entry and note the MQTT topic displayed.
Device Information:
  • Manufacturer: Moes / Tuya
  • Device Type: 4-Button Scene Switch
  • Model: TS0044
  • Zigbee Manufacturer: _TZ3000_wkai4ga5
  • Zigbee2MQTT Device Info: Link to TS0044
  • Switch Button Action Correlations:
    1. Top-Left
    2. Top-Right
    3. Bottom-Left
    4. Bottom-Right
How to Use
  1. Import: Select the “Import Blueprint” button at the top of this post.
  2. Configure: Use the MQTT topic you found earlier in the “switch_topic” field. Assign actions to each button press (single, double, or hold) using the blueprint inputs.
  3. Test: Save and test your automation. If you run into any issues, feel free to leave a comment below.
Blueprint YAML
blueprint:
  name: Moes/Tuya 4-Button Scene Switch (TS0044)
  description: >
    Controls various entities based on single and double press actions from a Moes 4-Button Scene Switch.
  domain: automation
  input:
    switch_topic:
      description: The MQTT topic for the scene switch.
      selector:
        text:
    single_1:
      name: Action for 1 Single Press
      description: Action to run when button 1 is single pressed.
      selector:
        action: {}
    single_2:
      name: Action for 2 Single Press
      description: Action to run when button 2 is single pressed.
      selector:
        action: {}
    single_3:
      name: Action for 3 Single Press
      description: Action to run when button 3 is single pressed.
      selector:
        action: {}
    single_4:
      name: Action for 4 Single Press
      description: Action to run when button 4 is single pressed.
      selector:
        action: {}
    double_1:
      name: Action for 1 Double Press
      description: Action to run when button 1 is double pressed.
      selector:
        action: {}
    double_2:
      name: Action for 2 Double Press
      description: Action to run when button 2 is double pressed.
      selector:
        action: {}
    double_3:
      name: Action for 3 Double Press
      description: Action to run when button 3 is double pressed.
      selector:
        action: {}
    double_4:
      name: Action for 4 Double Press
      description: Action to run when button 4 is double pressed.
      selector:
        action: {}
    hold_1:
      name: Action for 1 hold Press
      description: Action to run when button 1 is held.
      selector:
        action: {}
    hold_2:
      name: Action for 2 hold Press
      description: Action to run when button 2 is held.
      selector:
        action: {}
    hold_3:
      name: Action for 3 hold Press
      description: Action to run when button 3 is held.
      selector:
        action: {}
    hold_4:
      name: Action for 4 hold Press
      description: Action to run when button 4 is held.
      selector:
        action: {}
  - platform: mqtt
    topic: !input switch_topic
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ trigger.payload == '1_single' }}"
        sequence: !input single_1
      - conditions:
            value_template: "{{ trigger.payload == '2_single' }}"
        sequence: !input single_2
      - conditions:
            value_template: "{{ trigger.payload == '3_single' }}"
        sequence: !input single_3
      - conditions:
            value_template: "{{ trigger.payload == '4_single' }}"
        sequence: !input single_4
      - conditions:
            value_template: "{{ trigger.payload == '1_double' }}"
        sequence: !input double_1
      - conditions:
            value_template: "{{ trigger.payload == '2_double' }}"
        sequence: !input double_2
      - conditions:
            value_template: "{{ trigger.payload == '3_double' }}"
        sequence: !input double_3
      - conditions:
            value_template: "{{ trigger.payload == '4_double' }}"
        sequence: !input double_4
      - conditions:
            value_template: "{{ trigger.payload == '1_hold' }}"
        sequence: !input hold_1
      - conditions:
            value_template: "{{ trigger.payload == '2_hold' }}"
        sequence: !input hold_2
      - conditions:
            value_template: "{{ trigger.payload == '3_hold' }}"
        sequence: !input hold_3
      - conditions:
            value_template: "{{ trigger.payload == '4_hold' }}"
        sequence: !input hold_4
mode: single
What did you mean with Mqtt Topic ?
in my logs shows ( 2024-09-28 14:50:18z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Moes Szene Switch/action', payload '1_hold'
Info 2024-09-28 14:50:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Moes Szene Switch', payload '{"action":"1_single","battery":100,"last_seen":"2024-09-28T14:50:32+02:00","linkquality":136,"voltage":3000}'
Info 2024-09-28 14:50:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Moes Szene Switch', payload '{"action":"","battery":100,"last_seen":"2024-09-28T14:50:32+02:00","linkquality":136,"voltage":3000}'
Info 2024-09-28 14:50:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Moes Szene Switch/action', payload '1_single'
trying to test with only one action
same here. it appears to be broken
This is the only solution which has worked for me!
Here is how I got it working!
I had a name in Z2M which had spaces so the topic had spaces and that did NOT WORK. Next thing is I was unable to save as seen in @dimacoupe screenshot, however after adding an item to every single option I was able to save and finally trigger all these buttons. Then after initial save then I went and removed the action on the buttons I didn’t want and everything works!
Working to see if there is a way to fix the underlying automation from not saving unless there is a value in every single button command as we speak and will update here
This (save bug) seems like a bug in HA and not the blueprint from what I can see so not sure how to fix it. But it only causes issue for first save and my workaround fixed it
I tried your solution but after completed each single options, i have always the same message for next options :
Do you have an idea ?
Do this, did work for me,
But it is something else wrong here, not working. Its get the command, but it cant connect it to a command.
Executed: January 8, 2025 at 02:20:47
Result:
result: false
conditions/0
[Unknown condition]
Result:
result: false entities:
I have made a new blueprint for thsi that works :slight_smile:
that works for me, tested with covers.
thanks a lot
@ChillZwix
This works great! Wish I had read this entire thread instead of first trying and troubleshooting :slight_smile:
You can even select the remote from a dropdown list instead of having to paste the MQTT topic.
:+1:
can you edit that it would not be mandatory to fill ALL actions?
short update in may 2025
the original blueprint checks for:
- conditions:
  •      - condition: template*
  •        value_template: "{{ trigger.payload == '4_single' }}"*
but my mqtt broker sends as part of the payload this:
payload '{"action":"1_single","battery":100,"linkquality":105,"voltage":3000}'
so correcting the blueprints conditions check to this did the trick for me :slight_smile:
- conditions:
  •        value_template: "{{ **trigger.payload_json.action == '1_single'** }}"*
thx to @sherlock-homo for providing the blueprint in first place :nerd_face:
Works as a charm :slight_smile: Thanks a lot.
That worked fine for me! Thanks a LOT!!
anyone have single button dimming (hold-to-dim) working? I have 4 devices to control with this and would love to be able to dim them. thx
Hi guys
I checked today and noticed that when entering an automation using this Blueprint, all the action settings are empty and there’s no option to choose a new action. I tried creating a new automation and the same thing happened. Is this happening for you as well, or is it just on my end? (Thanks for the help)
Works after a reboot here!
Would be great to have the blueprint updated. :slight_smile:
