Hi everybody,
I just upgraded to Z2MQTT 2.0 with actual HA Version.
So far so good,- I integrated the Switch (after short interruption since i needed to activate HA Intergration) and when I make a single atomation it works. The Blueprints available do not work,- any idea why or what I need to change in the YAML to make it work with the new Z2MQTT?
blueprint:
name: Tuya Zigbee 4 button remote
description: "Blueprint for use with Tuya Zigbee 4 button remote (TS0044_1) on Zigbee2MQTT"
domain: automation
input:
switch:
description: Tuya Zigbee 4 button remote to use
selector:
entity:
button_1_short_press:
name: Single Press - Button 1
description: Action to run on button 1 single press
default: []
selector:
action: null
button_1_hold:
name: Hold - Button 1
description: Action to run on button 1 long press
default: []
selector:
action: null
button_1_double_press:
name: Double Press - Button 1
description: Action to run on button 1 double press
default: []
selector:
action: null
button_2_short_press:
name: Single Press - Button 2
description: Action to run on button 2 single press
default: []
selector:
action: null
button_2_hold:
name: Hold - Button 2
description: Action to run on button 2 long press
default: []
selector:
action: null
button_2_double_press:
name: Double Press - Button 2
description: Action to run on button 2 double press
default: []
selector:
action: null
button_3_short_press:
name: Single Press - Button 3
description: Action to run on button 3 single press
default: []
selector:
action: null
button_3_hold:
name: Hold - Button 3
description: Action to run on button 3 long press
default: []
selector:
action: null
button_3_double_press:
name: Double Press - Button 3
description: Action to run on button 3 double press
default: []
selector:
action: null
button_4_short_press:
name: Single Press - Button 4
description: Action to run on button 4 single press
default: []
selector:
action: null
button_4_hold:
name: Long Press - Button 4
description: Action to run on button 4 long press
default: []
selector:
action: null
button_4_double_press:
name: Double Press - Button 4
description: Action to run on button 4 double press
default: []
selector:
action: null
mode: queued
- platform: state
entity_id: !input switch
condition:
- "{{ trigger.to_state.state != '' }}"
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- "{{ command == '1_single' }}"
sequence: !input button_1_short_press
- conditions:
- "{{ command == '1_double' }}"
sequence: !input button_1_double_press
- conditions:
- "{{ command == '1_hold' }}"
sequence: !input button_1_hold
- conditions:
- "{{ command == '2_single' }}"
sequence: !input button_2_short_press
- conditions:
- "{{ command == '2_double' }}"
sequence: !input button_2_double_press
- conditions:
- "{{ command == '2_hold' }}"
sequence: !input button_2_hold
- conditions:
- "{{ command == '3_single' }}"
sequence: !input button_3_short_press
- conditions:
- "{{ command == '3_double' }}"
sequence: !input button_3_double_press
- conditions:
- "{{ command == '3_hold' }}"
sequence: !input button_3_hold
- conditions:
- "{{ command == '4_single' }}"
sequence: !input button_4_short_press
- conditions:
- "{{ command == '4_double' }}"
sequence: !input button_4_double_press
- conditions:
- "{{ command == '4_hold' }}"
sequence: !input button_4_hold
Thanks in advance
