Moes 4-gang switch from Ali Express
Hi all,
Since I can only find help/info when using ZHA integration, which I’m not looking for, I\m posting the question here. I hope someone can help out.
I have bought two 4-gang Moes switches via Ali Express. Currently I have them added to my Zigbee Gateway (Silvercrest LIDL) where I have added all my Tuya devices. In Home Assistant it says it’s not supported by Tuya and I can only set scenes in the Tuya app, which kinda defeats the purpose of using Home Assistant for everything.
Here are my questions:
  • Is there a way, without using ZHA, to configure and set automations, in Home Assistant?
  • Is there a Zigbee gateway which does work, again without using ZHA, with these switches, so I can setup and program them in HA?
  • If I do need to use ZHA, I see that the SkyConnect dongle is a good alternative. Can I use all my Tuya devices via this Dongle?
  • If you have multiple floors, what is the best way to setup SkyConnect dongles?
    I was thinking of using USB-to-LAN for this purpose on every floor.
Br,
Steve
All Tuya gateways are basicly the same, so if it does not work with the Lidl gateway, no use to buy another Tuya gateway.
Probably, but no guarantee. Check https://zigbee.blakadder.com/ for what is supported.
Using ZHA, you can only use one Skyconnect dongle. If you want to use more then one, you can use ZHA for one, and (one or more instances of) Zigbee2MQTT for the others.
Hi Francis,
Thanks for your reply. Ok, so Zigbee is Zigbee as long as it supports 3.0.
I thhought as much but always good to check.
I have found that Tuya cloud does see the device as a ZC-YED 四键场景开关(无遥控功能)but now what. I would really like to setup the switches in Home Assistant (scenes and automations) without buying new stuff again.
Br,
Steve
Hello! I literally set this up tonight as my first ever Zigbee device. I got a Home Assistant Green the other day, plugged in a SONOFF Zigbee USB adapter (at the end of a USB extension cord), and then had to wait until I could find CR2430 batteries for the Moes switch.
I got the batteries today, then installed one in the Moes switch.
Then I opened Home Assistant in my browser, and went to Settings > Devices & services and clicked the Devices tab.
Then I clicked ADD DEVICE.
Then I clicked Add Zigbee Device.
Then I held down one of the buttons on the Moes switch for a while until all the lights started flashing.
Then it just showed up in Home Assistant!
I added it as a device (after supplying a name and choosing an area), then created an automation using a button press on the Moes switch as the trigger. Worked great!
Good luck! I hope this helped!
  • Chris
