Could anyone share their method to pair the blind motors Moes AM43 with Deconz ?
I managed to pair one motor (adding as a sensor/switch, then adding as a light), it worked for one unit but not with the other motors I own.
The one that worked showed as a smart plug, then is exposed to HA, and I can control it.
For the other motors, when pairing, it shows up as battery and they are not exposed to HA.
I’ve tried to delete the node in the Deconz gui, restart the pairing process in Phozcons, tried to factory reset the motor restarting the pairing process, they are always showing as battery device.
What step did I miss ?
Thanks !
Johan
