Moes BAT-80A Smart Bluetooth Dual Power Controller
Hi guys, i need to control the state of my transfer switch.
From factory i can control from Tuya app and from Moes app.
From HA says unsupported from tuya oficial and tuyalocal does not work because is connecting using a Bluetooth gateway.
Any directions how to start a new integration or is a lost cause ?
Thank you.
Hi, check it!
But:
Hubs are currently supported, but with limitations. Each connection to a sub device uses a separate network connection, but like other Tuya devices, hubs are usually limited in the number of connections they can handle, with typical limits being 1 or 3, depending on the specific Tuya module they are using. This severely limits the number of sub devices that can be connected through this integration.
So you can manage limited sub devices.
