hy did you fiind the setings (problem is there no status if idle or heating).Thank you!
Add this to your climate file, replace existing part with this.
HVAC_MODE_SETS = {
āmanual/autoā: {
HVAC_MODE_HEAT: āmanualā,
HVAC_MODE_AUTO: āautoā,
āManual/Autoā: {
HVAC_MODE_HEAT: āManualā,
HVAC_MODE_AUTO: āAutoā,
āManual/Programā: {
HVAC_MODE_AUTO: āProgramā,
āTrue/Falseā: {
HVAC_MODE_HEAT: True,
ā1/0ā: {
HVAC_MODE_HEAT: ā1ā,
HVAC_MODE_AUTO: ā0ā,
It didnāt work for me. Changed my Climate Entity to Unavailable.
Anybody has any idea on how to make the fire icon turn on if the target temperature is higher than the actual, and off otherwise?
Are you sure you edited it correctly? Also did you do a restart after the changes? Mine work perfect all 3 of them
So once again, go to climate file finder section HVAV_MODE_SETS change that text with the above. Restart HA, add thermostat and all should work fine power icon to turn off, flame to turn on and calendar to set to program mode.
Yes! You are right. It works now. Turns out that copying and pasting your code left me with the wrong quotes on the yaml file.
May I suggest you edit HVAC_MODE_SETS
and put it in code mode?
Again, thanks for the quick reply.
I think now there are 2 things missing on this integration, that the tuya_local
already has:
The Comfort / ECO that shows the mode on the screen.
The ability to Lock
Both things are available for the same hardware on the Tuya_Local integration but not available on the LocalTuya integration (which is the one we are talking about here)
I canāt see nothing in your screenshot.
Canāt get the auto mode to be overriden by the manual mode for sayā¦ an hour, and then go back to auto modeā¦
Hey Net786,
Iām running HA on a rasp (Hassio) and have this issue with auto showing up instead of the manual setting.
I tried to follow your advice to add the lines in the climate file, but Iām not sure to understand where to find this file.
I integrated the Thermostat by LocalTuya integration.
Could you please help me out?
Thanks!
Hey,
It is under custom components , local tuya, climate
Thank you!
I have this in my climate file. Where should I add what you pasted (that I see in my config already by the way)?:
"""Platform to locally control Tuya-based climate devices."""
import asyncio
import logging
from functools import partial
import voluptuous as vol
from homeassistant.components.climate import (
DEFAULT_MAX_TEMP,
DEFAULT_MIN_TEMP,
DOMAIN,
ClimateEntity,
from homeassistant.components.climate.const import (
CURRENT_HVAC_HEAT,
CURRENT_HVAC_IDLE,
HVAC_MODE_AUTO,
HVAC_MODE_HEAT,
HVAC_MODE_OFF,
PRESET_AWAY,
PRESET_ECO,
PRESET_HOME,
PRESET_NONE,
SUPPORT_PRESET_MODE,
SUPPORT_TARGET_TEMPERATURE,
SUPPORT_TARGET_TEMPERATURE_RANGE,
from homeassistant.const import (
ATTR_TEMPERATURE,
CONF_TEMPERATURE_UNIT,
PRECISION_HALVES,
PRECISION_TENTHS,
PRECISION_WHOLE,
TEMP_CELSIUS,
TEMP_FAHRENHEIT,
from .common import LocalTuyaEntity, async_setup_entry
from .const import (
CONF_CURRENT_TEMPERATURE_DP,
CONF_ECO_DP,
CONF_ECO_VALUE,
CONF_HEURISTIC_ACTION,
CONF_HVAC_ACTION_DP,
CONF_HVAC_ACTION_SET,
CONF_HVAC_MODE_DP,
CONF_HVAC_MODE_SET,
CONF_MAX_TEMP_DP,
CONF_MIN_TEMP_DP,
CONF_PRECISION,
CONF_PRESET_DP,
CONF_PRESET_SET,
CONF_TARGET_PRECISION,
CONF_TARGET_TEMPERATURE_DP,
CONF_TEMPERATURE_STEP,
_LOGGER = logging.getLogger(__name__)
HVAC_MODE_SETS = {
"manual/auto": {
HVAC_MODE_HEAT: "manual",
HVAC_MODE_AUTO: "auto",
"Manual/Auto": {
HVAC_MODE_HEAT: "Manual",
HVAC_MODE_AUTO: "Auto",
"Manual/Program": {
HVAC_MODE_AUTO: "Program",
"True/False": {
"1/0": {
HVAC_MODE_HEAT: "1",
HVAC_MODE_AUTO: "0",
HVAC_ACTION_SETS = {
"True/False": {
CURRENT_HVAC_HEAT: True,
CURRENT_HVAC_IDLE: False,
"open/close": {
CURRENT_HVAC_HEAT: "open",
CURRENT_HVAC_IDLE: "close",
"heating/no_heating": {
CURRENT_HVAC_HEAT: "heating",
CURRENT_HVAC_IDLE: "no_heating",
"Heat/Warming": {
CURRENT_HVAC_HEAT: "Heat",
CURRENT_HVAC_IDLE: "Warming",
PRESET_SETS = {
"Manual/Holiday/Program": {
PRESET_AWAY: "Holiday",
PRESET_HOME: "Program",
PRESET_NONE: "Manual",
TEMPERATURE_CELSIUS = "celsius"
TEMPERATURE_FAHRENHEIT = "fahrenheit"
DEFAULT_TEMPERATURE_UNIT = TEMPERATURE_CELSIUS
DEFAULT_PRECISION = PRECISION_TENTHS
DEFAULT_TEMPERATURE_STEP = PRECISION_HALVES
# Empirically tested to work for AVATTO thermostat
MODE_WAIT = 0.1
def flow_schema(dps):
"""Return schema used in config flow."""
return {
vol.Optional(CONF_TARGET_TEMPERATURE_DP): vol.In(dps),
vol.Optional(CONF_CURRENT_TEMPERATURE_DP): vol.In(dps),
vol.Optional(CONF_TEMPERATURE_STEP): vol.In(
[PRECISION_WHOLE, PRECISION_HALVES, PRECISION_TENTHS]
vol.Optional(CONF_MAX_TEMP_DP): vol.In(dps),
vol.Optional(CONF_MIN_TEMP_DP): vol.In(dps),
vol.Optional(CONF_PRECISION): vol.In(
vol.Optional(CONF_HVAC_MODE_DP): vol.In(dps),
vol.Optional(CONF_HVAC_MODE_SET): vol.In(list(HVAC_MODE_SETS.keys())),
vol.Optional(CONF_HVAC_ACTION_DP): vol.In(dps),
vol.Optional(CONF_HVAC_ACTION_SET): vol.In(list(HVAC_ACTION_SETS.keys())),
vol.Optional(CONF_ECO_DP): vol.In(dps),
vol.Optional(CONF_ECO_VALUE): str,
vol.Optional(CONF_PRESET_DP): vol.In(dps),
vol.Optional(CONF_PRESET_SET): vol.In(list(PRESET_SETS.keys())),
vol.Optional(CONF_TEMPERATURE_UNIT): vol.In(
[TEMPERATURE_CELSIUS, TEMPERATURE_FAHRENHEIT]
vol.Optional(CONF_TARGET_PRECISION): vol.In(
vol.Optional(CONF_HEURISTIC_ACTION): bool,
class LocaltuyaClimate(LocalTuyaEntity, ClimateEntity):
"""Tuya climate device."""
def __init__(
self,
device,
config_entry,
switchid,
**kwargs,
"""Initialize a new LocaltuyaClimate."""
super().__init__(device, config_entry, switchid, _LOGGER, **kwargs)
self._state = None
self._target_temperature = None
self._current_temperature = None
self._hvac_mode = None
self._preset_mode = None
self._hvac_action = None
self._precision = self._config.get(CONF_PRECISION, DEFAULT_PRECISION)
self._target_precision = self._config.get(
CONF_TARGET_PRECISION, self._precision
self._conf_hvac_mode_dp = self._config.get(CONF_HVAC_MODE_DP)
self._conf_hvac_mode_set = HVAC_MODE_SETS.get(
self._config.get(CONF_HVAC_MODE_SET), {}
self._conf_preset_dp = self._config.get(CONF_PRESET_DP)
self._conf_preset_set = PRESET_SETS.get(self._config.get(CONF_PRESET_SET), {})
self._conf_hvac_action_dp = self._config.get(CONF_HVAC_ACTION_DP)
self._conf_hvac_action_set = HVAC_ACTION_SETS.get(
self._config.get(CONF_HVAC_ACTION_SET), {}
self._conf_eco_dp = self._config.get(CONF_ECO_DP)
self._conf_eco_value = self._config.get(CONF_ECO_VALUE, "ECO")
self._has_presets = self.has_config(CONF_ECO_DP) or self.has_config(
CONF_PRESET_DP
_LOGGER.debug("Initialized climate [%s]", self.name)
@property
def supported_features(self):
"""Flag supported features."""
supported_features = 0
if self.has_config(CONF_TARGET_TEMPERATURE_DP):
supported_features = supported_features | SUPPORT_TARGET_TEMPERATURE
if self.has_config(CONF_MAX_TEMP_DP):
supported_features = supported_features | SUPPORT_TARGET_TEMPERATURE_RANGE
if self.has_config(CONF_PRESET_DP) or self.has_config(CONF_ECO_DP):
supported_features = supported_features | SUPPORT_PRESET_MODE
return supported_features
@property
def precision(self):
"""Return the precision of the system."""
return self._precision
@property
def target_precision(self):
"""Return the precision of the target."""
return self._target_precision
@property
def temperature_unit(self):
"""Return the unit of measurement used by the platform."""
if (
self._config.get(CONF_TEMPERATURE_UNIT, DEFAULT_TEMPERATURE_UNIT)
== TEMPERATURE_FAHRENHEIT
return TEMP_FAHRENHEIT
return TEMP_CELSIUS
@property
def hvac_mode(self):
"""Return current operation ie. heat, cool, idle."""
return self._hvac_mode
@property
def hvac_modes(self):
"""Return the list of available operation modes."""
if not self.has_config(CONF_HVAC_MODE_DP):
return None
return list(self._conf_hvac_mode_set) + [HVAC_MODE_OFF]
@property
def hvac_action(self):
"""Return the current running hvac operation if supported.
Need to be one of CURRENT_HVAC_*.
if self._config.get(CONF_HEURISTIC_ACTION, False):
if self._hvac_mode == HVAC_MODE_HEAT:
if self._current_temperature < (
self._target_temperature - self._precision
self._hvac_action = CURRENT_HVAC_HEAT
if self._current_temperature == (
if self._hvac_action == CURRENT_HVAC_HEAT:
if self._hvac_action == CURRENT_HVAC_IDLE:
self._hvac_action = CURRENT_HVAC_IDLE
if (
self._current_temperature + self._precision
) > self._target_temperature:
return self._hvac_action
@property
def preset_mode(self):
"""Return current preset."""
return self._preset_mode
@property
def preset_modes(self):
"""Return the list of available presets modes."""
if not self._has_presets:
return None
presets = list(self._conf_preset_set)
if self._conf_eco_dp:
presets.append(PRESET_ECO)
return presets
@property
def current_temperature(self):
"""Return the current temperature."""
return self._current_temperature
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
return self._target_temperature
@property
def target_temperature_step(self):
"""Return the supported step of target temperature."""
return self._config.get(CONF_TEMPERATURE_STEP, DEFAULT_TEMPERATURE_STEP)
@property
def fan_mode(self):
"""Return the fan setting."""
return NotImplementedError()
@property
def fan_modes(self):
"""Return the list of available fan modes."""
async def async_set_temperature(self, **kwargs):
"""Set new target temperature."""
if ATTR_TEMPERATURE in kwargs and self.has_config(CONF_TARGET_TEMPERATURE_DP):
temperature = round(kwargs[ATTR_TEMPERATURE] / self._target_precision)
await self._device.set_dp(
temperature, self._config[CONF_TARGET_TEMPERATURE_DP]
def set_fan_mode(self, fan_mode):
"""Set new target fan mode."""
async def async_set_hvac_mode(self, hvac_mode):
"""Set new target operation mode."""
if hvac_mode == HVAC_MODE_OFF:
await self._device.set_dp(False, self._dp_id)
return
if not self._state and self._conf_hvac_mode_dp != self._dp_id:
await self._device.set_dp(True, self._dp_id)
# Some thermostats need a small wait before sending another update
await asyncio.sleep(MODE_WAIT)
self._conf_hvac_mode_set[hvac_mode], self._conf_hvac_mode_dp
async def async_turn_on(self) -> None:
"""Turn the entity on."""
async def async_turn_off(self) -> None:
"""Turn the entity off."""
async def async_set_preset_mode(self, preset_mode):
"""Set new target preset mode."""
if preset_mode == PRESET_ECO:
await self._device.set_dp(self._conf_eco_value, self._conf_eco_dp)
return
self._conf_preset_set[preset_mode], self._conf_preset_dp
@property
def min_temp(self):
"""Return the minimum temperature."""
if self.has_config(CONF_MIN_TEMP_DP):
return self.dps_conf(CONF_MIN_TEMP_DP)
return DEFAULT_MIN_TEMP
@property
def max_temp(self):
"""Return the maximum temperature."""
return self.dps_conf(CONF_MAX_TEMP_DP)
return DEFAULT_MAX_TEMP
def status_updated(self):
"""Device status was updated."""
self._state = self.dps(self._dp_id)
self._target_temperature = (
self.dps_conf(CONF_TARGET_TEMPERATURE_DP) * self._target_precision
if self.has_config(CONF_CURRENT_TEMPERATURE_DP):
self._current_temperature = (
self.dps_conf(CONF_CURRENT_TEMPERATURE_DP) * self._precision
if self._has_presets:
if (
and self.dps_conf(CONF_ECO_DP) == self._conf_eco_value
self._preset_mode = PRESET_ECO
else:
for preset, value in self._conf_preset_set.items(): # todo remove
if self.dps_conf(CONF_PRESET_DP) == value:
self._preset_mode = preset
break
else:
self._preset_mode = PRESET_NONE
# Update the HVAC status
if self.has_config(CONF_HVAC_MODE_DP):
if not self._state:
self._hvac_mode = HVAC_MODE_OFF
else:
for mode, value in self._conf_hvac_mode_set.items():
if self.dps_conf(CONF_HVAC_MODE_DP) == value:
self._hvac_mode = mode
break
else:
# in case hvac mode and preset share the same dp
self._hvac_mode = HVAC_MODE_AUTO
# Update the current action
for action, value in self._conf_hvac_action_set.items():
if self.dps_conf(CONF_HVAC_ACTION_DP) == value:
self._hvac_action = action
async_setup_entry = partial(async_setup_entry, DOMAIN, LocaltuyaClimate, flow_schema)
Hey, what version of local Tuya are you using?
Itās 4.1.1 by rospogrigio
I am using a BHT-002 thermostat under HA 2023.2.3 using LocalTuya v5.0.0.
Is there any way to capture the hvac_action attribute, i.e. the actual state of the thermostat (whether heating is active or not, that is) and not just set the mode to auto/manual and controlling the temperature?
I found a list of DPs in a github bug issue (Climate platform Ā· Issue #439 Ā· rospogrigio/localtuya Ā· GitHub) where this action is not defined/included.
Any ideas whether the DP which shows the hvac_action status is available?
Hi guys
iām trying to configure my BHT-002 wireless with localtuya, but even if i complete the configuration, i get an āunavailableā climate entity.
Can anyone share a screen of the conf of a working BHT-002 with localtuya?
Hi mate,
This is my first post here, just arrived trying to get some help on my mistaken order of 5 bht -002 GALWā¦.
My heating system is based in water flooring but connected to a water boiler, then when I did the order I choose GA type but after receiving and installed today the water boiler is always working even when the thermostats are not requesting any kind of operation to the water boiler.
I need to set up the thermostats wit dry contact
I have sent a message to the AliExpress seller just to know if I can return the goods and receive the right ones but as today is Friday and they said they are not working on weekends, I was looking for an alternative solution.
Is there any other option to convert GA into GC type?
I saw your post and if Iām not wrong youāre using a GA but the correct one for you is GC. Then youāre not connecting the two wires from the water boiler but only one in the number 2 relay. Is that correct? From my absolute unknown let me ask you if this would cause any kind of damage to the water heating flooring system or the water boiler.
This is my first attempt of automation and my Intention is to use it with smart life (tuya app) for the moment.
Thanks!!
Br
Andova
Hey Kendryn,
This is how my thermostat is set up.
Also, I had a lot of problems after setting the ECO presetā¦ so Iām not using it anymore and donāt recommend doing so. Itās rather useless anyway since you can change the target temp whichever way you want with HA.
Be sure NOT to use ANY Scan Interval on the previous āscreenā or you will have lots of problems with āunavailable deviceā. If you have set it by mistakeā¦ I think the only way to remove it is to edit out of your āconfig/.storage/core.config_entriesā file without having to remove the whole integration. Trying to edit the entity via the integrationās dashboard didnāt remove this entry from my config, I had to remove it manually.
Cheers
Hi, I have these thermostats at home and I have one question. Is it possible to get information from the current temperature sensor in HA? I couldnāt find this entity anywhere.
