After some help for updating my HA Installation I managed to bind my Moes in wall 2 gang switch (TS0012 von _TZ3000). One trigger switches a light directly connected the other one is just used as a button for controlling a socket adapter (also connected to a light).
Long story short, all worked for about 1 week, whilst I changed nothing special.
Now the directly connected light just turns off after some seconds when I switch it on. The second controlled light sometimes does the same but when it is on and I try to switch the main light it turns both of them off after a short time. I also tried deactivating all automations to that switch so that it would work like a normal in-wall switch but still the same.
Device signature:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0100",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006"
"out_clusters": [
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006"
"out_clusters": []
"manufacturer": "_TZ3000_18ejxno0",
"model": "TS0012",
"class": "zhaquirks.tuya.ts001x.TuyaDoubleNoNeutralSwitch_2"
