Hi
I just bought two Moes Scene Switches (TS004F). The pairing seems to work but then, actions are not triggered in HA.
Same issue with both switches by the way.
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0820",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0004",
"0x1000"
"out_clusters": [
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x000a",
"0x0019",
"0x0300",
"0x1000"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0006"
"out_clusters": []
"3": {
"profile_id": 260,
"in_clusters": [
"0x0006"
"out_clusters": []
"4": {
"profile_id": 260,
"in_clusters": [
"0x0006"
"out_clusters": []
"manufacturer": "_TZ3000_xabckq1v",
"model": "TS004F",
"class": "zhaquirks.tuya.ts004f.TuyaSmartRemote004FDMS"
I am using a ConBee II with ZHA.
