Control a climate entity with a Zigbee Moes Smart Rotary Dial.
This is my first EVER blueprint so please be kind. Currently only designed to work with this specific Moes Smart Rotary Switch
This Blueprint allows you to adjust the temperature of a climate entity using linear or non-linear modes, with optional delay settings. Non-linear mode is particularly useful for devices without a screen (or where a screen can’t be seen from) where you need to track temperature changes by counting knob turns.
For now the blueprint is only available for ZHA. If I get a chance I will update it to allow for Zigbee2MQTT.
21/08/24 Quick update.
I posted this and then somehow immediately broke the code. This has now hopefully been fixed. Re-importing the blueprint should result in the correct behaviour occuring.
