Up until now, I have only created basic automations using the GUI of Home Assistant. Recently, I purchased a Moes Knob from Aliexpress and discovered two Blueprints compatible with it.
The problem:
When using the knob, it logs the following output:
Turn Knob Step event was fired with parameters: {'step_mode': 0, 'step_size': 13, 'transition_time': 1, 'options_mask': None, 'options_override': None}
Here, step_mode: 0
or 1
indicates whether the knob was turned right or left, respectively. The step_size
shows how far the knob was turned, in increments of 13. However, the Blueprints I found only respond to the direction the knob is turned, without considering the step_size
My question is: How can I create an automation that triggers when the knob is turned and extracts the corresponding values (step_mode
and step_size
) to use them as a basis for further actions, such as adjusting the volume of a media player or dimming lights based on the step_size
I would appreciate any guidance on how to approach this and would be happy to share my results if I get it up and running!
