I’m having some issues binding my knob to a zigbee bulb in Zigbee2mqtt. Is there a trick to it? I’ve set up the binding from the knob in zigbee2mqtt but pressing the button and twisting the knob is not having any effect on the bulb.
Go to groups in z2m tab and make a new group called whatever then add the knob and (zigbee) bulb to that group.
Thanks I was missing that the bulb and knob need to be in the same group. Works great!
Hi, how did you make it being supported? Mine just shows unsupported device in z2m and I havent found much helpful information in how to get it running.
Thank you!
I’ve forked your blueprint with some improvements, including step percent configuration for both, pressed and unpressed rotations, and different lights for pressed and unpressed rotations (it allows me to control two lights with a single knob, but same light could be assigned for both if that’s not needed)
blueprint:
name: ZHA - Moes Smart Knob for lights
description: 'Control lights with a Moes Smart Knob.
You can set functions for a single press. This allows you to assign, e.g., a scene
or anything else.
Rotating left/right will change the brightness smoothly of the selected light.
Not all functionality of the device is available at time of writing, e.g. double
press, long press and press and rotate.
Original blueprint by seamus65 (https://gist.github.com/seamus65/939a147634942dd885c8704334627f93).
Improved by GonzaloAlbito (https://gist.github.com/gonzaloalbito/3dc06702e941e08298ea9bfade731731).
Version 2022-11-15.'
domain: automation
input:
remote:
description: Moes Knob to use
selector:
device:
integration: zha
manufacturer: _TZ3000_qja6nq5z
model: TS004F
multiple: false
light:
description: The light(s) to control
selector:
entity:
domain: light
step_percent:
description: Light pecent change for each knob step
selector:
number:
mode: slider
min: 0
max: 100
unit_of_measurement: "%"
default: 20
press_light:
description: The light(s) to control when pressed
selector:
entity:
domain: light
press_step_percent:
name: Pressed light step
description: Light pecent change for each knob step when pressed
selector:
number:
mode: slider
min: 0
max: 100
default: 5
single_press:
description: Action to run on single press
default: []
selector:
action: {}
source_url: https://gist.github.com/gonzaloalbito/3dc06702e941e08298ea9bfade731731
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: '{{ trigger.event.data.command }}'
cluster_id: '{{ trigger.event.data.cluster_id }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
mode: '{% if command != ''toggle'' %} {{ trigger.event.data.args[0] }} {% endif %}'
steps: '{% if command != ''toggle'' %} {{ (trigger.event.data.args[1] / 12.5 ) | int }} {% endif %}'
step_percent: !input step_percent
press_step_percent: !input press_step_percent
- choose:
- conditions:
- '{{ cluster_id == 6 }}'
- '{{ endpoint_id == 1 }}'
- '{{ command == ''toggle'' }}'
sequence: !input single_press
- conditions:
- '{{ cluster_id == 8 }}'
- '{{ command == ''step'' }}'
- '{{ mode == ''StepMode.Up'' }}'
sequence:
- repeat:
while:
- condition: template
value_template: '{{ repeat.index < 2 }}'
sequence:
- service_template: light.turn_on
target: !input light
data_template:
brightness_step_pct: '{{ step_percent * steps }}'
transition: 0.5
- conditions:
- '{{ mode == ''StepMode.Down'' }}'
sequence:
- repeat:
while:
sequence:
data_template:
brightness_step_pct: '-{{ step_percent * steps }}'
transition: 0.5
- conditions:
- '{{ cluster_id == 768 }}'
- '{{ command == ''step_color_temp'' }}'
sequence:
- repeat:
while:
sequence:
target: !input press_light
data_template:
brightness_step_pct: '{{ press_step_percent * steps }}'
transition: 0.5
- conditions:
sequence:
- repeat:
while:
sequence:
data_template:
brightness_step_pct: '-{{ press_step_percent * steps }}'
transition: 0.5
Nothing fancy… paired it with z2m, and got it working. I found that z2m has two operation modes for this button: command and event. I’m using “command” now.
Strange, I paired it with z2m, and under Manufacturer is written Unsupported. I guess thats why I can’t see it in my devices and entities. I did repair it, nothing changed. How did you select a operation mode?
Edit:
Sorry, Its not working. is it supposed to work with ZHA OR Zigbee2Mqtt?
I tried with ZHA and it says no device found.
It’s for ZHA.
I think there may be more than a single model. You may need to change these values
by the ones displayed in your device when you go to its information page:
Hi!
I was using your wonderful yaml, but encountered these three error today
This is weird as I have two same device and it seems like they are sending different event when rotary is turned. One that works
This one doesn’t work
I have updated the blueprint as the enpoint id no longer exists, hopefully it works again.
There are two modes with the Moes smart knob, toggled with a triple press, and this blueprint only works with one mode, so if it isn’t working try a triple press and try again.
Here’s my updated version : zha_moes_smart_knob_lights.yaml · GitHub
It’s way simpler as it de-duplicates the increasing and decreasing actions. It also implements a speed percent argument.
Also it doesn’t use the argsarray but the params dict for readability.
Thank you. I added long press action and removed manufacturer lock.
blueprint:
or anything else.
Version 2022-11-15.
Edited by Gordio'
domain: automation
input:
remote:
selector:
device:
integration: zha
model: TS004F
multiple: false
light:
selector:
entity:
domain: light
step_percent:
selector:
number:
mode: slider
min: 0
max: 100
default: 20
press_light:
selector:
entity:
domain: light
press_step_percent:
selector:
number:
mode: slider
min: 0
max: 100
default: 5
single_press:
default: []
selector:
action: {}
long_press:
description: Action to run on long press
default: []
selector:
action: {}
mode: restart
- platform: event
event_data:
- variables:
- choose:
- conditions:
- conditions:
- '{{ command == ''move_hue'' }}'
sequence: !input long_press
- conditions:
sequence:
- repeat:
while:
sequence:
data_template:
transition: 0.5
- conditions:
sequence:
- repeat:
while:
sequence:
data_template:
transition: 0.5
- conditions:
sequence:
- repeat:
while:
sequence:
data_template:
transition: 0.5
- conditions:
sequence:
- repeat:
while:
sequence:
data_template:
transition: 0.5
Were you ever able to get this working as a volume control? I’m receiving my devices tomorrow and I was hoping to use them for this purpose.
Hello! I have been having the same problem for a few weeks now.
Could you solve it?
Possible to change the light color via the rotary method? Example blue , red or etc
Well, I leave this in case it happens to someone, I solve it by deleting the Device and adding it again. He rarely did Blueprint automation but it didn’t reflect on the Devices he commanded.
Hello everyone,
here is my blueprint to use the Moes Smart Knob as Volume Controller. I’ve made it very flexible (no hardcoded media-controll). Hope you like it.
1: Your Moes Device
2: Your Media-Player to controll the volume
3. Optional (second) Device for the Button-Push-Action
4. What to when pushing the button (I use ADB from FireTV to Start / Pause Playback)
blueprint:
name: ZHA - Moes Tuya Smart Knob (TS004F) controller for media_player
description: Steuern Sie die Lautstärke des Media Players und setzen Sie Play/Pause darauf
domain: automation
input:
remote:
description: Moes Tuya Smart Knob-Gerät zur Verwendung
selector:
device:
integration: zha
model: TS004F
media_player:
description: Der MediaPlayer, der gesteuert werden soll
selector:
entity:
domain: media_player
volume_step_size:
name: Volume Step Size
description: Wert der Drehung, der einer Lautstärke-Änderung von 1% entspricht
default: 13
selector:
number:
min: 1
max: 100
mode: slider
step: 1
secondary_media_player:
name: Secondary MediaPlayer
description: Ein weiterer MediaPlayer, der bei einem Tastendruck gesteuert werden soll
selector:
entity:
button_custom_action:
name: Button Custom Action
description: Benutzerdefinierte Aktion, die beim Tastendruck ausgeführt werden soll
selector:
action: {}
mode: restart
- platform: event
event_data:
device_id: !input 'remote'
- variables:
args: '{{ trigger.event.data.args }}'
step_type: >
{% if args %}
{% if 'StepMode.Up' in args %}
up
{% elif 'StepMode.Down' in args %}
down
{% endif %}
{% else %}
none
{% endif %}
amount: '{{ (args and args.split(",")[1] | int(default=50)) or 50 }}'
rate: '{{ (args and args.split(",")[2] | int(default=1)) or 1 }}'
volume_step_size: !input 'volume_step_size'
# --- Media Player ---
media_player_entity: !input 'media_player'
media_player_is_on: "{{ states(media_player_entity.entity_id) not in ['off', 'unavailable', 'idle'] }}" # Überprüft, ob der Media Player eingeschaltet oder am Abspielen ist.
- choose:
- conditions:
- '{{ command == "toggle" }}'
sequence: !input 'button_custom_action'
- conditions:
- '{{ command == "step" }}'
- '{{ media_player_is_on }}'
sequence:
- repeat:
count: '{{ rate }}'
sequence:
- service: media_player.volume_set
target: !input 'media_player'
volume_level: >
{% set current_volume = state_attr(media_player_entity.entity_id, 'volume_level') | float %}
{% set volume_increment = (amount | float) / volume_step_size / 100 %}
{% if step_type == 'up' %}
{% set new_volume = current_volume + volume_increment %}
{% elif step_type == 'down' %}
{% set new_volume = current_volume - volume_increment %}
{% endif %}
{% set new_volume = new_volume if 0 <= new_volume <= 1 else 0 if new_volume < 0 else 1 %}
{{ new_volume }}
- delay: '00:00:01' # Eine konstante Verzögerung zwischen den Befehlen
I used some of the code from your blueprint and created a blueprint for anyone who wants to import it directly.
It also supports push and rotate, increase and decrease volume.
Here is the link to it : ZHA - Moes Smart Knob for Media Player · GitHub
