Blueprint to control lights using a Moes Smart Knob and ZHA.
You can set functions for a single press. This allows you to assign, e.g., a scene or anything else.
Rotating left/right will change the brightness smoothly of the selected light by 5% each step.
Pressing and Rotating left/right will change the brightness smoothly of the selected light by 20% each step.
Not all functionality of the device is available at time of writing, e.g. double press and long press.
Screen
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: ZHA - Moes Smart Knob for lights
description: 'Control lights with a Moes Smart Knob.
Rotating left/right will change the brightness smoothly of the selected light.
Not all functionality of the device is available at time of writing, e.g. double press, long press and press and rotate.'
domain: automation
input:
remote:
description: Moes Knob to use
selector:
device:
integration: zha
manufacturer: _TZ3000_4fjiwweb
model: TS004F
light:
description: The light(s) to control
selector:
entity:
domain: light
single_press:
description: Action to run on single press
default: []
selector:
action: {}
source_url: https://gist.github.com/seamus65/939a147634942dd885c8704334627f93
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
command: '{{ trigger.event.data.command }}'
cluster_id: '{{ trigger.event.data.cluster_id }}'
args: '{% if trigger.event.data.args[0] == 0 %} 0 {% elif trigger.event.data.args[0] == 1 %} 1 {% elif trigger.event.data.args[0] == 3 %} 3 {% endif %}'
- choose:
- conditions:
- '{{ command == ''toggle'' }}'
- '{{ cluster_id == 6 }}'
sequence: !input 'single_press'
- conditions:
- '{{ command == ''step'' }}'
- '{{ cluster_id == 8 }}'
- '{{ args == 0 }}'
sequence:
- repeat:
while:
- condition: template
value_template: "{{ repeat.index < 2 }}"
sequence:
- service_template: light.turn_on
target: !input 'light'
data_template:
brightness_step_pct: 5
transition: 0.5
- conditions:
- '{{ args == 1 }}'
sequence:
- repeat:
while:
sequence:
data_template:
brightness_step_pct: -5
transition: 0.5
- conditions:
- '{{ command == ''step_color_temp'' }}'
- '{{ cluster_id == 768 }}'
- '{{ args == 1 }}'
sequence:
- repeat:
while:
sequence:
data_template:
brightness_step_pct: 20
transition: 0.5
- conditions:
- '{{ args == 3 }}'
sequence:
- repeat:
while:
sequence:
data_template:
brightness_step_pct: -20
transition: 0.5
but it might be dim down buttom pressed for rotate counter clockwise and dim up for clockwise?
