Moes trv ztrv-by-100
I have a ZigBee MOES TRV (ZTRV-BY-100), I have added it to my HA instance using ZHA via a Conbee2 stick.
I can get data no problem and also change most settings, however I can’t change the set point through HA. The option is there and I can move the temperature value on the dial, however it doesn’t appear to change the temperature set value on the device and quickly reverts back in HA.
The TRV is on the manual setting , mode is heat, preset is none.
Does anyone know why HA doesn’t seem to be able to control the set value in this setup and what needs to be done to allow the control?
+1 for this. Exactly the same for me…
+1… Same here…
Hey James, same problem here. Did you find any solution?
There is a quirk for zha available! It is not perfect, but together with better thermostat it can be used! _TZE200_b6wax7g0 - Moes BRT-100 - appropriate quirk and access to device schedule
