Moes/Tuya 4-Button Scene Switch TS004F
blueprint:
  name: Zigbee2MQTT - Tuya 4-Button Scene Switch TS004F
  description: Automate your Tuya 4-Button Scene Switch (TS004F) via Zigbee2MQTT. Link - https://www.zigbee2mqtt.io/devices/TS004F.html
  domain: automation
  input:
    switch:
      description: Tuya 4-Button Wireless Switch
      selector:
        entity:
          domain: sensor
          integration: mqtt
    button_one_short_press:
      name: Button 1 - Single Press
      description: Action to run on button 1 (bottom-left) single press
      default: []
      selector:
        action: null
    button_one_hold:
      name: Button 1 - Hold
      default: []
      selector:
        action: null
    button_one_double_press:
      name: Button 1 - Double Press
      default: []
      selector:
        action: null
    button_two_short_press:
      name: Button 2 - Single Press
      description: Action to run on button 2 (lower-right) single press
      default: []
      selector:
        action: null
    button_two_hold:
      name: Button 2 - Hold
      default: []
      selector:
        action: null
    button_two_double_press:
      name: Button 2 - Double Press
      default: []
      selector:
        action: null
    button_three_short_press:
      name: Button 3 - Single Press
      description: Action to run on button 3 (top-right) single press
      default: []
      selector:
        action: null
    button_three_hold:
      name: Button 3 - Hold
      default: []
      selector:
        action: null
    button_three_double_press:
      name: Button 3 - Double Press
      default: []
      selector:
        action: null
    button_four_short_press:
      name: Button 4 - Single Press
      description: Action to run on button 4 (top-left) single press
      default: []
      selector:
        action: null
    button_four_hold:
      name: Button 4 - Long Press
      description: Action to run on button 4 (lower-left) long press
      default: []
      selector:
        action: null
    button_four_double_press:
      name: Button 4 - Double Press
      default: []
      selector:
        action: null
  source_url: https://gist.github.com/whalelion/5f19317ea530687a768ed2c34218cbc4
mode: single
max_exceeded: silent
variables:
  command: "{{ trigger.payload }}"
  topic: "{{ trigger.topic }}"
  switch_name: !input "switch"
  deviceName: "{{ state_attr(switch_name, 'friendly_name') }}"
  - platform: mqtt
    topic: zigbee2mqtt/+/action
  - choose:
      - conditions:
          - "{{ topic.split('/')[1].replace('/', '') == deviceName.split(' ')[0]}}"
        sequence:
          - choose:
              - conditions:
                  - "{{ command == '1_single' }}"
                sequence: !input "button_one_short_press"
              - conditions:
                  - "{{ command == '2_single' }}"
                sequence: !input "button_two_short_press"
              - conditions:
                  - "{{ command == '3_single' }}"
                sequence: !input "button_three_short_press"
              - conditions:
                  - "{{ command == '4_single' }}"
                sequence: !input "button_four_short_press"
              - conditions:
                  - "{{ command == '1_double' }}"
                sequence: !input "button_one_double_press"
              - conditions:
                  - "{{ command == '2_double' }}"
                sequence: !input "button_two_double_press"
              - conditions:
                  - "{{ command == '3_double' }}"
                sequence: !input "button_three_double_press"
              - conditions:
                  - "{{ command == '4_double' }}"
                sequence: !input "button_four_double_press"
              - conditions:
                  - "{{ command == '1_hold' }}"
                sequence: !input "button_one_hold"
              - conditions:
                  - "{{ command == '2_hold' }}"
                sequence: !input "button_two_hold"
              - conditions:
                  - "{{ command == '3_hold' }}"
                sequence: !input "button_three_hold"
              - conditions:
                  - "{{ command == '4_hold' }}"
                sequence: !input "button_four_hold"
