Moes Tuya Switch reacting with delay when pressed
I’ve recently acquired a Moes Tuya battery powered wall switch. I don’t know the model number but HASS identifies it as “TS0041”.
The switch is paired with a Sonoff Zigbee 3.0 USB-Dongle Plus-E that I’ve updated to the most current firmware, which is integrated into my HASS setup using ZHA.
When I trigger my automation with this switch there is a ~0.5 to 1 second delay between the key press and the corresponding light turning on. When I replace the trigger with an Ikea Shortcut Button the light turns on immediately when the button is pressed.
Do you have any idea or recommendation how this delay can be removed?
Same problem here, did not find a solution until now …
I use the blueprint to create the automation perhaps is the time to read and execute the yaml file.
The automation is responding quickly but it takes time to switch the light.
