Moes TV01 TS0601 TRV internal Temperature Sensor does not update
I recently got the Moes TV01 TS0601 TRV (_TZE200_e9ba97vf) and integrated them with ZHA.
Everything works like a charm and i can control the TRV’s Target Temperature fine, but the internal temperature sensor does only update when i change the the Target Temperature.
I am afraid, that the thermostats will keep heating up, even though the target temperature is already reached. I can not find an option (or automation) that would refresh the temperature sensor regularly (like 5min intervals).
Each of the devices has 3 switches that i have no clue of what they do, they are just called “on_off”, “on_off2” and “on_off3”.
Does anybody know how to fix this issue?
EDIT: I also looked into this issue:
but what they mentioned did sadly not fix my issue.
as i have the same problem (no update of measuered temp) and as well no clue about the 3 buttons :slight_smile: just want to know if you have a solution at the moment?
thanks
The 1st switch is boost mode, the 2nd is child lock. I also have no clue about the 3rd switch.
