Hi guys, im very very newbie in this. Bought Home Assistant green recently, with Sonoff_Zigbee_3.0_USB_Dongle_Plus E. Added all my stuff there which i was using for years with tuya zigbee router etc, so all good more or less.
Have a question… I have a wall switch connected by wires to a ordinary lamps. On other side i have another wall 3 button switch, which is using only 2 buttons by wires and 3rd button isnt connected to anyting. So in HA made an automation to toggle 1st switch by 2nd switch third button. And actually works fine, except that light indicator usually doesnt match state of light. It should lighted up when light is on, and off when light is off. I didnt find any attributes regarding that light indicator in HA , but i did have option to control this when was using cloud based tuya app, so that means there is an option to control thoes indicators states.
Is there any option to manually add thoes attributes or smth in YAML or any other way?
THANKS! <3
The indicator light is hardwired internally and will toggle every time the switch is operated. All you can do is turn the light off permanently or invert its operation ie have the light go off when the switch is on. This is one of mine in Zigbee2MQTT.
Thanks for your reply! I use ZHA ( was trying to set up Z2M, but no luch, errors all the time ) . So i dont have this option in UI ((
