Moes ZT-SR-EU4 Star Ring 4 Gang Scene Switch via Zigbee2MQTT device trigger
This blueprint supports the Moes ZT-SR-EU4 control via MQTT | Zigbee2MQTT scene switch using modern device triggers, replacing sensor entities as used in other similar blueprints. Enjoy!
Edit: Removing sensor entities was reverted in fix(ignore): Add back Home Assistant legacy action sensor by Koenkk · Pull Request #25192 · Koenkk/zigbee2mqtt · GitHub and the sensor entities have been restored. Of course, this blueprint still works, but users upgrading to the 2.0 release when it’s out won’t have any breaking automations to fix up.
blueprint:
  name: Moes ZT-SR-EU4 Star Ring 4 Gang Scene Switch via Zigbee2MQTT device trigger
  description: Automate your Star Ring 4 Gang Scene Switch via Zigbee2MQTT.
  domain: automation
  input:
    device:
      description: Moes ZT-SR-EU4 Star Ring 4 Gang Scene Switch to use
      selector:
        device:
          filter:
            - manufacturer: Moes
              model: Star Ring 4 Gang Scene Switch (ZT-SR-EU4)
          multiple: false
    button_one_short_press:
      name: Single Press - Button 1
      description: Action to run on button 1 (upper-left) single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Double Press - Button 1
      description: Action to run on button 1 (upper-left) double press
      default: []
      selector:
        action: {}
    button_one_long_press:
      name: Long Press - Button 1
      description: Action to run on button 1 (upper-left) long press
      default: []
      selector:
        action: {}
    button_two_short_press:
      name: Single Press - Button 2
      description: Action to run on button 2 (upper-right) single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Double Press - Button 2
      description: Action to run on button 2 (upper-right) double press
      default: []
      selector:
        action: {}
    button_two_long_press:
      name: Long Press - Button 2
      description: Action to run on button 2 (upper-right) long press
      default: []
      selector:
        action: {}
    button_three_short_press:
      name: Single Press - Button 3
      description: Action to run on button 3 (lower-left) single press
      default: []
      selector:
        action: {}
    button_three_double_press:
      name: Double Press - Button 3
      description: Action to run on button 3 (upper-right) double press
      default: []
      selector:
        action: {}
    button_three_long_press:
      name: Long Press - Button 3
      description: Action to run on button 3 (lower-left) long press
      default: []
      selector:
        action: {}
    button_four_short_press:
      name: Single Press - Button 4
      description: Action to run on button 4 (lower-right) single press
      default: []
      selector:
        action: {}
    button_four_double_press:
      name: Double Press - Button 4
      description: Action to run on button 4 (lower-right) double press
      default: []
      selector:
        action: {}
    button_four_long_press:
      name: Long Press - Button 4
      description: Action to run on button 4 (lower-right) long press
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/moes-zt-sr-eu4-star-ring-4-gang-scene-switch-via-zigbee2mqtt-device-trigger/808142
mode: queued
max_exceeded: silent
  - platform: device
    domain: mqtt
    device_id: !input device
    type: action
    subtype: 1_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 1_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 1_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: 2_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 2_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 2_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: 3_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 3_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 3_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_hold
- choose:
  - conditions:
    - "{{ trigger.payload == '1_single' }}"
    sequence: !input "button_one_short_press"
  - conditions:
    - "{{ trigger.payload == '2_single' }}"
    sequence: !input "button_two_short_press"
  - conditions:
    - "{{ trigger.payload == '3_single' }}"
    sequence: !input "button_three_short_press"
  - conditions:
    - "{{ trigger.payload == '4_single' }}"
    sequence: !input "button_four_short_press"
  - conditions:
    - "{{ trigger.payload == '1_double' }}"
    sequence: !input "button_one_double_press"
  - conditions:
    - "{{ trigger.payload == '2_double' }}"
    sequence: !input "button_two_double_press"
  - conditions:
    - "{{ trigger.payload == '3_double' }}"
    sequence: !input "button_three_double_press"
  - conditions:
    - "{{ trigger.payload == '4_double' }}"
    sequence: !input "button_four_double_press"
  - conditions:
    - "{{ trigger.payload == '1_hold' }}"
    sequence: !input "button_one_long_press"
  - conditions:
    - "{{ trigger.payload == '2_hold' }}"
    sequence: !input "button_two_long_press"
  - conditions:
    - "{{ trigger.payload == '3_hold' }}"
    sequence: !input "button_three_long_press"
  - conditions:
    - "{{ trigger.payload == '4_hold' }}"
    sequence: !input "button_four_long_press"
