MoesGo 'MS-105BZ' in Pairing mode
Dear Community,
i have a MS-105BZ dual zigbee dimmer.
I do not know how to get it into pairing mode.
In the manual it says:
After the wiring of switch module is done, press the reset switch for 10 times (keep time interval not too short) until the beep sounds continuously and rapidly as Di-Di-Di… for pairing mode.
I tried clicking the stupid buttons thousands of times in different intervals. There is just nothing changing. The lights turn on or off but there is no pairing mode.
Does anybody have an idea?
Any luck with this, @Infraviored ? Having the same issue.
Ich habe einen MS-105B-Dimmer, der über WLAN funktioniert. Bei diesem Gerät hatte ich ebenfalls das Problem. Das WLAN, in welchem der Dimmer vorher aktiv war, habe ich während des Zurücksetzens deaktiviert. Anschließend habe ich ihn zehn Mal ein- und ausgeschaltet, und schon war ich im Pairing-Modus.
I have the same issue.
Can’t put the MS-105BZ zigbee in pairing mode
I tried everything
I think I tried everything, after connecting it to a push button.
  • 10x on the switch (+/- long interval)
  • Cut the power supply (5x in a row)
  • long press
If you have an idea, I’m interested
I have successfully paired it by keeping the reset button pressed until it started ringing, after about 10s.
After pairing it, no controls appeared in home assistant, so it remained useless.
but in the mqtt2zigbee they state it is compatible… it should appear!
by the way what reset button you do mean? my dimmer module has no button at all… but just the L S and N entries.
I got it in pairing mode, but my model is the MS-105Z (missing the B, so models are slightly different)
I did connect a regular switch and made sure it was off. Then I switched it ON, after 1 second OFF again and I repeated the process 10 times and then it started the beep-ing and Z2M recognized it and added it into my device list.
Any luck with the MS-105BZ model? Same issue here
Hey! I’ve just managed to pair it!
The secret:
Put your zigbee coordinator to pairing mode. (ZHA or Z2M)
When you push the rocker switch 10 times, at the last push (the 10th) keep it on until you hear the two beeps then release.
After that it will start beeping and will pair with ZHA or Z2M… :slight_smile:
