Ok, here I am again,
I adapted the ezr2mqtt.yaml to my ip addresses and started the ezr2mqtt and the mosquito plug in. However, none diverse show up.
In the mosquito broker I get following protocol
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[15:58:45] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:58:45] INFO: Starting NGINX for authentication handling...
[15:58:46] INFO: Starting mosquitto MQTT broker...
1635778726: mosquitto version 1.6.12 starting
1635778726: |-- *** auth-plug: startup
[15:58:46] INFO: Successfully send discovery information to Home Assistant.
[15:58:47] INFO: Successfully send service information to the Supervisor.
1635778726: Config loaded from /etc/mosquitto/mosquitto.conf.
1635778726: Loading plugin: /usr/share/mosquitto/auth-plug.so
1635778726: ├── Username/password checking enabled.
1635778726: ├── TLS-PSK checking enabled.
1635778726: └── Extended authentication not enabled.
1635778726: Opening ipv4 listen socket on port 1883.
1635778726: Opening ipv6 listen socket on port 1883.
1635778726: Opening websockets listen socket on port 1884.
1635778726: Warning: Mosquitto should not be run as root/administrator.
1635778726: mosquitto version 1.6.12 running
1635778726: New connection from 127.0.0.1 on port 1883.
1635778726: Socket error on client <unknown>, disconnecting.
1635778728: New connection from 172.30.33.3 on port 1883.
1635778728: New client connected from 172.30.33.3 as auto-6605ED7D-6FFC-3512-7698-8F78E6758477 (p2, c1, k60).
1635778729: New connection from 172.30.32.1 on port 1883.
1635778729: New client connected from 172.30.32.1 as 4I2jI7FKZ3IZL7x3X0n1xI (p2, c1, k60).
1635778766: New connection from 172.30.32.2 on port 1883.
1635778766: Socket error on client <unknown>, disconnecting.
1635778886: New connection from 172.30.32.2 on port 1883.
1635778886: Socket error on client <unknown>, disconnecting.
1635779007: New connection from 172.30.32.2 on port 1883.
1635779007: Socket error on client <unknown>, disconnecting.
1635779127: New connection from 172.30.32.2 on port 1883.
1635779127: Socket error on client <unknown>, disconnecting.
1635779247: New connection from 172.30.32.2 on port 1883.
1635779247: Socket error on client <unknown>, disconnecting.
1635779367: New connection from 172.30.32.2 on port 1883.
1635779367: Socket error on client <unknown>, disconnecting.
1635779487: New connection from 172.30.32.2 on port 1883.
1635779487: Socket error on client <unknown>, disconnecting.
1635779607: New connection from 172.30.32.2 on port 1883.
1635779607: Socket error on client <unknown>, disconnecting.
1635779727: New connection from 172.30.32.2 on port 1883.
1635779727: Socket error on client <unknown>, disconnecting.
1635779847: New connection from 172.30.32.2 on port 1883.
1635779847: Socket error on client <unknown>, disconnecting.
1635779964: New connection from 172.30.32.1 on port 1883.
1635779964: New client connected from 172.30.32.1 as 2Y0q3fkzmaCzbtY3yjNs0j (p1, c1, k60).
1635779964: Client 2Y0q3fkzmaCzbtY3yjNs0j disconnected.
1635779967: New connection from 172.30.32.2 on port 1883.
1635779967: Socket error on client <unknown>, disconnecting.
1635780087: New connection from 172.30.32.2 on port 1883.
1635780087: Socket error on client <unknown>, disconnecting.
1635780095: Socket error on client auto-6605ED7D-6FFC-3512-7698-8F78E6758477, disconnecting.
1635780141: New connection from 172.30.33.3 on port 1883.
1635780141: New client connected from 172.30.33.3 as auto-E7B018B9-20E5-0486-FB62-FDD8F9A5DC64 (p2, c1, k60).
1635780157: Socket error on client 4I2jI7FKZ3IZL7x3X0n1xI, disconnecting.
1635780169: New connection from 172.30.32.1 on port 1883.
In ezr2mqtt addon I do get the following protocol
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Subscribed: 5 (128,)
Subscribed: 6 (128,)
Subscribed: 14 (128,)
Subscribed: 15 (128,)
Subscribed: 23 (128,)
Subscribed: 24 (128,)
Subscribed: 32 (128,)
Subscribed: 33 (128,)
Subscribed: 41 (128,)
Subscribed: 42 (128,)
Subscribed: 50 (128,)
Subscribed: 51 (128,)
is anyone able to flag what the problem might be?
