FYI: I posted this same question on mysensors forum a week ago, but no one was able to answer my question.
I am attempting to incorporate a moisture sensor into HA but getting could not convert to float errors in the logs. The sensor does show up in mysensors.json but not in the gui.
Home Assistant 0.94.4
I am using a simple FC-28 moisture sensor: VCC, Gnd, D0 connected to D6 of the UNO and A0 connected to D7.
SoilMoistSensor Sketch:
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <[email protected]>
* Copyright (C) 2013-2018 Sensnology AB
* Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* DESCRIPTION
* Arduino soil moisture based on gypsum sensor/resistive sensor to avoid electric catalyse in soil
* Required to interface the sensor: 2 * 4.7kOhm + 2 * 1N4148
* Gypsum sensor and calibration:
* DIY: See http://vanderleevineyard.com/1/category/vinduino/1.html
* Built: Davis / Watermark 200SS
* http://www.cooking-hacks.com/watermark-soil-moisture-sensor?_bksrc=item2item&_bkloc=product
* http://www.irrometer.com/pdf/supportmaterial/sensors/voltage-WM-chart.pdf
* cb (centibar) http://www.irrometer.com/basics.html
* 0-10 Saturated Soil. Occurs for a day or two after irrigation
* 10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
* 30-60 Usual range to irrigate or water (except heavy clay soils).
* 60-100 Usual range to irrigate heavy clay soils
* 100-200 Soil is becoming dangerously dry for maximum production. Proceed with caution.
* Connection:
* D6, D7: alternative powering to avoid sensor degradation
* A0, A1: alternative resistance measuring
* Based on:
* "Vinduino" portable soil moisture sensor code V3.00
* Date December 31, 2012
* Reinier van der Lee and Theodore Kaskalis
* www.vanderleevineyard.com
* Contributor: epierre
// Copyright (C) 2015, Reinier van der Lee
// www.vanderleevineyard.com
// This program is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_RF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
#include <math.h> // Conversion equation from resistance to %
#include <MySensors.h>
// Setting up format for reading 3 soil sensors
#define NUM_READS (int)10 // Number of sensor reads for filtering
#define CHILD_ID 0
MyMessage msg(CHILD_ID, V_LEVEL);
uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
long buffer[NUM_READS];
int idx;
/// @brief Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
typedef struct {
int moisture; //!< Moisture
long resistance; //!< Resistance
} values;
const long knownResistor = 4700; // Constant value of known resistor in Ohms
int supplyVoltage; // Measured supply voltage
int sensorVoltage; // Measured sensor voltage
values valueOf[NUM_READS]; // Calculated moisture percentages and resistances to be sorted and filtered
int i; // Simple index variable
void setup()
// initialize the digital pins as an output.
// Pin 6,7 is for sensor 1
// initialize the digital pin as an output.
// Pin 6 is sense resistor voltage supply 1
pinMode(6, OUTPUT);
// Pin 7 is sense resistor voltage supply 2
pinMode(7, OUTPUT);
void presentation()
sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
present(CHILD_ID, S_MOISTURE);
void loop()
measure(6,7,1);
Serial.print ("\t");
Serial.println (average());
long read1 = average();
measure(7,6,0);
long read2= average();
long sensor1 = (read1 + read2)/2;
Serial.print ("resistance bias =" );
Serial.println (read1-read2);
Serial.print ("sensor bias compensated value = ");
Serial.println (sensor1);
Serial.println ();
//send back the values
send(msg.set((int32_t)ceil(sensor1)));
// delay until next measurement (msec)
sleep(SLEEP_TIME);
void measure (int phase_b, int phase_a, int analog_input)
// read sensor, filter, and calculate resistance value
// Noise filter: median filter
for (i=0; i<NUM_READS; i++) {
// Read 1 pair of voltage values
digitalWrite(phase_a, HIGH); // set the voltage supply on
delayMicroseconds(25);
supplyVoltage = analogRead(analog_input); // read the supply voltage
digitalWrite(phase_a, LOW); // set the voltage supply off
delay(1);
digitalWrite(phase_b, HIGH); // set the voltage supply on
sensorVoltage = analogRead(analog_input); // read the sensor voltage
digitalWrite(phase_b, LOW); // set the voltage supply off
// Calculate resistance
// the 0.5 add-term is used to round to the nearest integer
// Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
delay(1);
addReading(resistance);
Serial.print (resistance);
Arduino Serial Monitor:
11679 TSF:MSG:SEND,105-105-0-0,s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=OK:2
11687 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
11693 TSF:TDI:TSL
11695 MCO:SLP:WUP=-1
11697 TSF:TRI:TSB
34 11 0 -11 0 11 23 23 11 0 10
-21 -10 10 11 0 -11 -22 -11 -10 11 -5
resistance bias =15
sensor bias compensated value = 2
11756 TSF:MSG:SEND,105-105-0-0,s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=OK:2
11765 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
11770 TSF:TDI:TSL
11772 MCO:SLP:WUP=-1
11773 TSF:TRI:TSB
11 22 23 11 -11 -11 0 11 23 11 9
-11 -11 -11 0 11 11 0 -11 -22 -11 -5
resistance bias =14
11833 TSF:MSG:SEND,105-105-0-0,s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=OK:2
11842 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
11847 TSF:TDI:TSL
11849 MCO:SLP:WUP=-1
11851 TSF:TRI:TSB
23 0 0 -11 11 23 23 23 0 -11 8
-10 0 10 22 0 -22 -22 -10 11 11 -1
resistance bias =9
sensor bias compensated value = 3
11911 TSF:MSG:SEND,105-105-0-0,s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=OK:3
11919 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
11924 TSF:TDI:TSL
// Averaging algorithm
void addReading(long resistance)
buffer[idx] = resistance;
idx++;
if (idx >= NUM_READS) {
idx = 0;
long average()
long sum = 0;
for (int i = 0; i < NUM_READS; i++) {
sum += buffer[i];
return (long)(sum / NUM_READS);
Mysensors.json Moisture Sensor:
"105": {
"sensor_id": 105,
"children": {
"0": {
"id": 0,
"type": 35,
"description": "",
"values": {
"37": "3"
"type": 17,
"sketch_name": "Soil Moisture Sensor Reve",
"sketch_version": "1.0",
"battery_level": 0,
"protocol_version": "2.3.1",
"heartbeat": 0
HA Logs:
ValueError: could not convert string to float: '2.1.1'
2019-07-03 12:35:20 DEBUG (SyncWorker_2) [mysensors.persistence] Saving sensors to persistence file /home/homeassistant/.homeassistant/mysensors.json
2019-07-03 12:35:47 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,105-105-0,s=0,c=1,t=37,pt=4,l=4,sg=0:1
2019-07-03 12:35:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 105 child 0
2019-07-03 12:35:47 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Soil Moisture Sensor Reve 105 0: value_type 37, value = 1
2019-07-03 12:35:47 ERROR (MainThread) [homeassistant.components.mysensors.device] Error updating Soil Moisture Sensor Reve 105 0
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/mysensors/device.py", line 103, in update
await self._async_update_callback()
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/mysensors/device.py", line 129, in _async_update_callback
await self.async_update_ha_state(True)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 225, in async_update_ha_state
self._async_write_ha_state()
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 258, in _async_write_ha_state
unit_of_measurement = self.unit_of_measurement
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/mysensors/sensor.py", line 75, in unit_of_measurement
if (float(self.gateway.protocol_version) >= 1.5
2019-07-03 12:35:50 DEBUG (SyncWorker_8) [mysensors.persistence] Saving sensors to persistence file /home/homeassistant/.homeassistant/mysensors.json
