Moj.IO Addon
I Want use my car Moj.io tracker (syncUP Drive T-Mobile) as presence device.
I’d like to see this as well, since these devices are becoming more and more popular, and able to pull stats from the OBDII sensor… have to poke around and find the api.
Is there a solution to getting data from the SyncUp Drive into Home Assistant yet?
I see it is being worked on here:
Are you still looking for this? I am using that approach as a custom component, and I can try to dig up the Sync-Up client-id and client-secret if you want to give it a try.
Edit:
I have posted here the config what is required for SyncUp Drive.
And contacted the original author to move it to a custom_component repo.
