I have a Garage Door switch module (Qubino D1) I have created a switch in HA which works but doesnt turn off it remembers last state in HA so I want to set up a momentary switch
I have installed the twecked/hass-momentary component and I thought I had followed the instructions but I am missing something
It also says put Momentary in the configuration.yaml but I get this message
Where does this go - configuration.yaml or config/momentary_init_py or somewhere else
switch:
No need to reinstall. I’m saying, remove what you added to configuration.yaml, reboot, and then re-add the lines to configuration.yaml. It should no longer say it can’t be found.
Ok well I removed Momentary: from configuration.yaml and restarted HA and I still get the same message when I add Momentary: back in the Configuration.yaml
Either I am missing something - probably
or it doesnt work
You said reboot…I restarted HA I didnt reboot my Dell
