I will be installing two gate motors soon and apart from their RF remote (rolling code), they have a manual push button type switch to wire to the house. Anytime the button is pressed, it closes the circuit and the motor figures out to open/close/half-open etc.
Now I thought about wiring this to GPIO0 in a sonoff Basic but this would not fit my purpose completely.
I want to retain a physical switch on the wall but also to get the status in home assistant. I could flash esphome on an esp but I can’t wrap my mind on how to get a physical switch in the picture.
I would “remove” the wall switch then add a switch to the ESP and use this as the new “wall switch”.
The new switch only triggers an automation that closes the circuit where the old switch was using a relay or optocoupler depending on what would be needed.
To get the current state, not sure how that would be possible.
Using your remotes will get it out of sync
