Is anyone aware of a way to monitor the battery level of a leisure 12v battery?
I have a Fibaro RGBW controller and Qubino Shutter DC controller, which both are supplied by the 12v but they don’t actually show the level of the input voltage.
Are there any other zwave devices that show the input voltage level?
Or another way to monitor the 12v battery, maybe using the GPIO on the Pi?
You could use Fibaro Smart Implant. It can be configured as voltage sensor, though I believe in range of up to 10V only, so some additional voltage divider would be required and ‘scaling’ of output in hassio.
Thanks, yeah it’s limited to 10v. I’ll see what’s involved with calculating this in HA. If not, If anyone has another device for 12v+ that would be better
