Hey guys,
I run a virtual radar server which gets data from a number of ads-b feeders around my state, I want to be able to get TTS notifications when particular flights or aircraft enter range of my network if receivers.
I can get a Json data feed of the currently visible aircraft, but the exact location of the string I want to be notified about may change depending on a number of factors.
Is there any way to search the file for any mention of a specific string ?
I think node red might be my best chance ?
Eg I want a tts notification when a flight with route HND to SYD appears, or a callsign VH-OJA, Etc.
Similar to what this does, but in home assistant.
And here’s the Json:
https://radar.rei.moe/virtualradar/AircraftList.json
Note it may be empty if you’re checking it in USA daytime… Depends how busy the air is here in Sydney.
Thank you!
