Monitor a webpage for any change
Hi!
I need to get an alert when a website changes. Scraper does not work, cause there is nothing specific to monitor. I found a script, but I can’t get it to run…
Example with Home Assistant:
  - platform: command_line
    command: >-
      python3 -c "import hashlib, requests; response = requests.get('https://www.home-assistant.io/'); print(hashlib.sha256(response.content).hexdigest())"
    scan_interval: 10800
source: Monitoring changes in webpages with Home Assistant
Is there an easy solution?
