been racking my brain trying to see if there is a way to monitor the change of two attributes within two separate entities in a single node. The use case is monitoring thermostat changes in the house. i have two thermostats upstairs
and downstairs
. i am trying to trigger a flow if the attribute values of target_temp_high
or target_temp_low
change (not to a specific value). The reason for this is that i have some logic that sets the thermostats to specific temps, but if someone is uncomfortanle, i want them to be able to walk up to the thermostat, change it, then have the automation re-set things back to the standard after a period of time (like 30 minutes). I was troying with the trigger state node, but it seems to fail at the conditions since only one side of the temperature would change:
anyone have ideas on how to trigger this in a single node?
