Having the same issue, but also have to say I’m an absolute novice w.r.t. Arduino sketches (have dabbled a bit in ESPhome and managed to get a few things working :))
There doesnt seem to be a file in the git which is openable by Arduino. Have looked at all the files in there and noticed the platformio file, so also looked at that a bit, but it ended up being more confusing then helpfull…would love some assistance!
as already hinted on in my previous message, the response from @Climber10293 put us on the wrong track as the code linked to is Platformio code, and as such cannot be loaded into Arduino…(I think)
After some fiddling I got it up and running using vscode with the platformio stuff enabled!
Now just to figure out how to get it into HA as I do see the values popping up (using mosquitto as a broker) if I just listen to the topic via the integrations page, but creating a sensor (based on the yaml from @Nathan_Byrer) with that topic listed does not seem to do anything if I add it as a normal sensor to my lovelace UI…
Anyway, hope this helps!
edit: already figured out the issue…the esp32 code sends an integer as mqtt code…so just replacing "{{ value_json.value }}" with "{{ value_json }}" did the trick!
Just added Inkbird IBT-4XS to OpenMQTTGateway development branch, I use the advertisement of the data so as to improve the sensor battery life instead of issuing a BLE connection to the sensor.
It is detected automatically and auto discovered into Home Assistant. You can find it directly into the device list.
I am trying to integrate Inkbird IBT-4XS in HA via an ESP32 module. I have had a look at the instructions but having a bit of difficulty working out what files I need to download.
I assume OpenMQTTGateway_sources.zip but not sure at all on which libraries to select. What adjustments to config.h file do I also need to complete. Any help would be appreciated.
Sorry to come back to you, but I am having an issue with compiling the ESP32 via Arduino with the following error occuring:
In file included from C:\Users\xxxxxx\AppData\Local\Temp\arduino_modified_sketch_80038\ZgatewayBT.ino:47: c:\users\xxxxxx\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2020r3\lib\gcc\xtensa-esp32-elf\8.4.0\include\stdatomic.h:40:9: error: ‘_Atomic’ does not name a type
typedef _Atomic _Bool atomic_bool;*
c:\users\xxxxxx\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2020r3\lib\gcc\xtensa-esp32-elf\8.4.0\include\stdatomic.h:41:9: error: ‘_Atomic’ does not name a type
typedef _Atomic char atomic_char;*
c:\users\xxxxxx\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2020r3\lib\gcc\xtensa-esp32-elf\8.4.0\include\stdatomic.h:42:9: error: ‘_Atomic’ does not name a type
typedef _Atomic signed char atomic_schar;*
c:\users\xxxxxx\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2020r3\lib\gcc\xtensa-esp32-elf\8.4.0\include\stdatomic.h:43:9: error: ‘_Atomic’ does not name a type
typedef _Atomic unsigned char atomic_uchar;*
I was able to successfully upload the sketch to an ESP8266 which was recognised in Home Assistant but this is not much good to me as I require a bluetooth device.
Assistance would be appreciated.
This looks really cool. Could you install OMG on a RPi0W, for example, to listen for the BLE advertisements feom the inkbird, and send them to an MQTT broker via WiFi? Or install it on an ESP32 module? Sorry, i don’t know anything about OMG.
Thanks for the offer of the binary file 1technophile. A brief note on how to load the binary file would be appreciated as well. Thank you.
email address is [email protected]
@Nathan_Byrer Thank you for posting this information. I was able to use your YAML as a basis to get my iBBQ 4BW operational within Home Assistant with alerts to my phone. The numbers input portion was the hurdle for me to overcome and once I was able to understand it, everything works like a charm and I can now setup alerts from within Home Assistant and not use the Inkbird app at all.
I am using local-tuya to manage and control the iBBQ 4BW without any issues.
Cool. I’ve just purchased the Inkbird IBT-4XS (having a smart home is getting more and more expensive ).
I’ve read some of the comments and docs now.
Which ESP32 to get that is the easiest solution to connect a Inkbird IBT-4XS?
I haven’t played around with ESP32 yet so this is a good start.
This is sooo exciting to get this integrated into Home Assistant
