Monitoring old dishwasher blueprint failed
Blueprint config:
alias: Vaatwas info
description: ''
use_blueprint:
  path: jgillula/advanced_appliance_power_monitor.yaml
  input:
    power_entity: sensor.vaatwas_lsc_power
    start_threshold: 5
    finish_threshold_delay:
      hours: 0
      minutes: 2
      seconds: 0
    on_start:
      - action: input_select.select_option
        metadata: {}
          option: Running
          entity_id: input_select.vaatwas_status
      - action: notify.mobile_app_telefoon_ward
        metadata: {}
          message: Vaatwas is bezig
    on_stop:
        metadata: {}
          option: Complete
        metadata: {}
          message: Vaatwas is klaar
      - action: counter.increment
        metadata: {}
        data: {}
          entity_id: counter.vaatwas_teller
    start_threshold_delay:
      hours: 0
      minutes: 1
      seconds: 0
    energy_entity: sensor.vaatwas_verbruik_kwh_helper
    finish_threshold: 0
Automation config:
mode: single
triggers:
  - platform: numeric_state
    entity_id: sensor.vaatwas_lsc_power
    for:
      hours: 0
      minutes: 1
      seconds: 0
    above: 5
actions:
  - variables:
      start_threshold: 5
      finish_threshold: 0
        hours: 0
        minutes: 1
        seconds: 0
      running_threshold_delay:
        hours: 0
        minutes: 0
        seconds: 0
        hours: 0
        minutes: 2
        seconds: 0
      start_time: >-
        {{ as_timestamp(now()) - start_threshold_delay.hours * 3600 -
        start_threshold_delay.minutes * 60 - start_threshold_delay.seconds }}
      initial_energy: |
        {% if energy_entity is not none %}
          {{ states(energy_entity) | float }}
        {% else %}
          0
        {% endif %}
  - variables:
      elapsed_time: >
        {% set elapsed_timedelta = now() - as_datetime(start_time) %} {{
        elapsed_timedelta.days * 86400 + elapsed_timedelta.seconds }}
      elapsed_days: '{{ (elapsed_time | int) // 86400 }}'
      elapsed_hours: '{{ ((elapsed_time | int) - ((elapsed_days|int) * 86400)) // 3600 }}'
      elapsed_minutes: >-
        {{ ((elapsed_time | int) - ((elapsed_days|int) * 86400) -
        ((elapsed_hours|int) * 3600)) // 60 }}
      elapsed_seconds: >-
        ((elapsed_hours|int) * 3600) - ((elapsed_minutes|int) * 60)) }}
      event_type: start
      energy_used: |
          {{ (states(energy_entity) | float) - initial_energy }}
        {% else %}
          0
        {% endif %}
      running_threshold_total_delay: >-
        {{ running_threshold_delay.hours * 3600 +
        running_threshold_delay.minutes * 60 + running_threshold_delay.seconds
      finish_threshold_total_delay: >-
        {{ finish_threshold_delay.hours * 3600 + finish_threshold_delay.minutes
        * 60 + finish_threshold_delay.seconds }}
  - variables:
        {{ (finish_threshold_total_delay + 1) if (running_threshold_total_delay
        < finish_threshold_total_delay) else running_threshold_total_delay }}
      running_threshold_delay_hours: '{{ running_threshold_total_delay // 3600 }}'
      running_threshold_delay_minutes: >-
        {{ (running_threshold_total_delay - running_threshold_delay_hours *
        3600) // 60 }}
      running_threshold_delay_seconds: >-
        {{ (running_threshold_total_delay - running_threshold_delay_hours * 3600
        - running_threshold_delay_minutes * 60) }}
        hours: '{{ running_threshold_delay_hours }}'
        minutes: '{{ running_threshold_delay_minutes }}'
        seconds: '{{ running_threshold_delay_seconds }}'
  - choose:
      - conditions: '{{ true }}'
        sequence:
            metadata: {}
              option: Running
            metadata: {}
  - repeat:
      until:
        - condition: template
          value_template: '{{ wait.trigger.id == "stop" }}'
      sequence:
        - wait_for_trigger:
              for: >-
                {{ finish_threshold_delay.hours }}:{{
                finish_threshold_delay.minutes }}:{{
              below: 0
            - platform: state
              entity_id:
                - sensor.vaatwas_lsc_power
              for: >-
                {{ running_threshold_delay.hours }}:{{
                running_threshold_delay.minutes }}:{{
                running_threshold_delay.seconds }}
        - variables:
            event_type: '{{ wait.trigger.id }}'
            energy_used: |
              {% else %}
                0
              {% endif %}
        - choose:
            - conditions: '{{ event_type == ''running'' }}'
              sequence:
                - variables:
                    elapsed_time: >-
                      %}{{ elapsed_timedelta.days * 86400 +
                    elapsed_hours: >-
                      // 3600 }}
                    elapsed_minutes: >-
                    elapsed_seconds: >-
                      60)) }}
                - choose:
                    sequence: []
            - conditions: '{{ event_type == ''stop'' }}'
              sequence:
                - variables:
                    elapsed_time: >
                      + finish_threshold_delay.hours * 3600 +
                      finish_threshold_delay.minutes * 60 +
                      finish_threshold_delay.seconds) %} {{
                    elapsed_hours: >-
                      // 3600 }}
                    elapsed_minutes: >-
                    elapsed_seconds: >-
                      60)) }}
                - choose:
                      sequence:
                          metadata: {}
                            option: Complete
                          metadata: {}
                          metadata: {}
                          data: {}
alias: Vaatwas info
description: ''
Automation info:
I have no idea where the problem could be find :frowning:
Regards,
Ward
