Monitoring other machine in the network
Hi all,
I’d like to monitor a NAS that I have in the Network. It’s a Linux based NAS so I can run scripts, etc. but was wondering if is there any component I can use.
thanks in advance.
Monitor how, exactly?
If you’re looking to monitor stats, you could try Glances. If your simply looking to monitor if it’s up, there should be an entry for it in known_devices if you have discovery and netdisco running.
Thanks for your reply.
Well, I’m thinking on things like temp, uptime, etc.
I’d like to integrate it in the HA dashboard more than building something extra.
I’d suggest setting up Glances and the HA Glances component, then you can pick what sensors from that to add to dashboard.
I did that and works great.
Thank you for the advice!
Glad to help! I have mine tricked out with all the Material Design Icons:
U ARE A LEGEND! U saved me tons of time as I am running Unraid 7 baremetal, I used to do HA in docker, but then I moved to HA os on VM as I needed the Cloudflare addon, but then I realized System Monitor is looking at HA VM…I was seconds away to kill myself but then…
