After installing a new solar panel, regulator and some modern lithium batteries on our cabin, I wanted to see if I could monitor these remotely. They all had a silly “app” that could be used to read BLE-data from the devices, but since they are located in a remote location, that did not really work. I started by installing a cheap android tablet and trying to pull the data by grabbing screenshots and using Tasker, I gave up, and started from scratch by setting up an RPI and starting to reverse engieneer the apps, and protocols they used.
After some months, I now have a working setup, where data is passively monitoried by BLE and GATT, and sent to my Home Assistant over MQTT.
The service currently support the following BLE-devices:
- SRNE regulators (monitored by the SolarLink APP: https://play.google.com/store/apps/details?id=com.shuorigf
- Lithium Batteries (monitored by the Meritsun APP: https://play.google.com/store/apps/details?id=com.meritsun.smartpower
- Victron Energy - VE.Direct devices - currently only their Phoenix inverters.
Data can be sent using either MQTT or JSON
Please don’t hesitate to fork it or send PRs if you want to have more devices supported.
