I have a Wemos D1 R1 and I need to control Atrea recuperation using analog write (PWM). I installed EPSHome, used monochromatic integration on pin D5. Unfortunately, it doesn’t work correctly for me. The controller does not behave linearly. When setting 40% in HA, 10% is set on the fan, between 40-50% the fan increases the speed to 20%, 60-70% is the fan to 60% and it keeps growing.
I tried to change the frequency and set the gamma to 1.0, but everything is the same.
Some idea? Alternatively, could the slider be adjusted somewhere in the settings to actually send 40% at 0%?
output:
- platform: esp8266_pwm
pin: D5
light:
- platform: monochromatic
output: output_component1
gamma_correct: 1
Thank you
Ivica
