I recently installed and set up a Monoprice 4-in-1 multi sensor (https://www.monoprice.com/product?p_id=15902) and a fair amount of restarting and reconnecting, the sensor seems to be communicating with my hub (RPi 2 B w/Aotec Gen 5 Z-stick). However I am running into the following issues:
- The latency on the motion sensor is very high. It takes between 5-10 seconds between walking past the sensor and triggering a message. Compare this to an Ecolink IR motion sensor I have that is nearly instantaneous.
- The temperature/luminance/humidity sensor readings do not update with any regular frequency and it is not clear why.
Does anyone else have a similar experience with this sensor? I have a feeling it simply isn’t a very good product and I should have chosen something else, but I am still holding out hope that I can get some use out of it.
Thanks,
Drew
