Hello
I have reached out to the thread for github and tried posting in the forum, creating this new entry because as of build 104 MOPAR still does not work… clean install.
In the logs I see the following:
Error during setup of component mopar
File "/usr/src/homeassistant/homeassistant/setup.py", line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File "/usr/src/homeassistant/homeassistant/components/mopar/__init__.py", line 68, in setup
data.update(now=None)
File "/usr/src/homeassistant/homeassistant/components/mopar/__init__.py", line 113, in update
self.tow_guides[index] = motorparts.get_tow_guide(self._session, index)
File "/usr/local/lib/python3.7/site-packages/motorparts/__init__.py", line 92, in wrapped
return function(*args)
File "/usr/local/lib/python3.7/site-packages/motorparts/__init__.py", line 106, in wrapped
return function(session, *args)
File "/usr/local/lib/python3.7/site-packages/motorparts/__init__.py", line 164, in get_tow_guide
'vin': profile['vehicles'][vehicle_index]['vin']
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 897, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.7/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 2 column 1 (char 1)
