Mopeka tank sensor
I got the Pro Check Mopeka sensor to monitor my propane tank, It works perfectly with Bluetooth on my iPhone app, but Home Assistant seems to be unable to fetch any data from it. I thought maybe the Bluetooth range on my HA was poor and looked into extenders and these esp32 proxies etc…
But the device is only 15-20 feet straight line and one wall away from my Raspberry board. So what could be causing this and how should I proceed? I don’t want to go on another shopping spree on Amazon to find out nothing worked.
Thanks for reading, looking forward to your comments :smiley:
Hi @zenmartian
You could try our Theengs Gateway Add-on which should also discover your Mopeka Pro Check sensor through Bluetooth.
Let us know how you get on.
