Mopeka Wi-Fi Bridge integration
Hello
We need a intergration for the mopeka wifi bridge that talks to the sensor and feed the data back to home assistant or mopeka cloud API
You have the Mopeka integration that listen directly to the sensors.
The WiFi bridge is probably not open and talks to cloud servers in an encrypted channel, so it will be near impossible to hack.
A ESPHome Bluetooth Proxy should do the job you’re asking for if your sensor is out of range of your HA host’s Bluetooth.
